Latest: Koodium
Overall: 7930
Visitors: 298
Total: 298
01: Home
41: Your Account
79: Home
81: Home
85: Home
86: Home
93: Home
96: Home
107: Home
114: Home
117: Home
129: Home
132: Home
151: Home
156: Home
167: Home
180: Home
191: Home
196: Home
202: Home
213: Photo Gallery
216: Photo Gallery
228: Photo Gallery
244: Home
249: Home
255: Home
257: Forums
262: Forums
263: Home
265: Forums
267: Home
271: Forums
272: Forums
273: Home
274: Forums
275: Forums
277: Forums
279: Forums
280: Home
281: Forums
282: Home
283: Forums
285: Home
286: Forums
287: Forums
288: Forums
289: Forums
290: Forums
291: Home
292: Forums
293: Forums
294: Forums
295: Forums
296: Forums
297: Home
298: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Very wierd need help :: Archived
Speedymarky2616
PostPosted: Fri Mar 09, 2007 2:32 am    Post subject: Very wierd need help
When I dry fire my bushy no leaks ever shoot fine and all but when I shoot paint After about a hundred shot sometimes I get a leak out of my noid region I,ve had this problem since I got the marker may it be to much lpr pressure? should I put more lube in my lpr. With the hpr lower should the lpr be lower or higher? maybe ram o-rings?
Ohh and when I shoot it twice he leak quits so It must be a seal
dementedpaintballer
PostPosted: Fri Mar 09, 2007 2:35 am    Post subject: Re: Very wierd need help
Seems like your LPR may be creeping up. Try cleaning and relubing your LPR and see if that fixes the problem.
BLAH!
Speedymarky2616
PostPosted: Fri Mar 09, 2007 2:41 am    Post subject: Re: Very wierd need help
Whats odd is its not when I dry fire do I want a good amount of lube? I use a pression lube from radio shack
dementedpaintballer
PostPosted: Fri Mar 09, 2007 2:48 am    Post subject: Re: Very wierd need help
Just a thin film of the lube is good. Too much can clog the LPR.
BLAH!
Speedymarky2616
PostPosted: Fri Mar 09, 2007 2:59 am    Post subject: Re: Very wierd need help
Maybe I need more lube on ram cause I beleave its after the noid goes off
PostPosted: Fri Mar 09, 2007 4:01 am    Post subject: Re: Very wierd need help
No, the problem is because of your LPR. You need to clean and re-lube it.
Speedymarky2616
PostPosted: Fri Mar 09, 2007 9:20 pm    Post subject: Re: Very wierd need help
Now I have a new problem. When I take off my tray the micro switch wont click but it will when put back together. is this a loose wire
bagel
PostPosted: Fri Mar 09, 2007 10:13 pm    Post subject: Re: Very wierd need help
I'd bet that it is a loose wire. First thing that I would check are wires that connect to the microswitch AT the microswitch. After that just check wires all around. That should be the issue.
NDFS7 and T2'd B2k4pds
Wild Adventure Paintball, Zamora, CA
Speedymarky2616
PostPosted: Sat Mar 10, 2007 1:28 am    Post subject: Re: Very wierd need help
Got it all fixed nothing was wrong just my wires pushed my microswitch foward barley and my trigger was set for that. so when The pressure was off it went to its resting position just bareley past my trigger stop
Last post by Koodium in Calendar of Events on Jan 07, 2021 at 07:23:52
How to make a snowman in animal crossing
Last post by zhanghuahua in Calendar of Events on Jan 05, 2021 at 07:48:06
How to make bells faster in ACNH?
Last post by Tonyfirst in Non ICD Gear Forum on Dec 19, 2020 at 07:39:19
How long will it take to get yourself a 99 in OSRS?
Last post by Tonyfirst in Calendar of Events on Dec 19, 2020 at 07:28:00
FS PRO for sale
Last post by nexttime in ICD Gear Forum on Dec 16, 2020 at 02:01:18
Last post by nexttime in ICD Gear Forum on Dec 16, 2020 at 01:49:50
