Latest: Skyzhay
Overall: 7947
Visitors: 451
Total: 451
102: Home
103: Home
112: Home
118: Home
119: Home
123: Home
126: Home
128: Home
155: Photo Gallery
171: Home
183: Photo Gallery
187: Photo Gallery
189: Photo Gallery
191: Photo Gallery
200: Photo Gallery
202: Home
213: Home
215: Photo Gallery
223: Home
226: Photo Gallery
259: Photo Gallery
262: Forums
263: Forums
266: Photo Gallery
267: Forums
268: Photo Gallery
269: Photo Gallery
271: Forums
272: Forums
273: Forums
274: Forums
275: Forums
277: Forums
278: Photo Gallery
279: Forums
280: Home
281: Forums
283: Photo Gallery
285: Forums
286: Home
287: Forums
288: Forums
289: Forums
290: Forums
291: Forums
292: Forums
293: Home
294: Forums
295: Photo Gallery
296: Forums
297: Forums
298: Photo Gallery
299: Forums
300: Forums
301: Photo Gallery
302: Forums
303: Photo Gallery
304: Forums
305: Forums
306: Forums
307: Forums
308: Forums
309: Forums
310: Forums
311: Forums
312: Photo Gallery
313: Forums
314: Photo Gallery
315: Forums
316: Home
317: Forums
318: Forums
319: Photo Gallery
320: Photo Gallery
321: Forums
322: Forums
323: Home
324: Home
325: Forums
326: Forums
327: Forums
328: Forums
329: Forums
330: Forums
331: Forums
332: Forums
333: Forums
334: Forums
335: Forums
336: Forums
337: Forums
338: Forums
339: Forums
340: Forums
341: Photo Gallery
342: Forums
343: Forums
344: Forums
345: Forums
346: Forums
347: Forums
348: Forums
349: Forums
350: Photo Gallery
351: Forums
352: Forums
353: Forums
354: Forums
355: Home
356: Forums
357: Photo Gallery
358: Forums
359: Forums
360: Forums
361: Forums
362: Forums
363: Photo Gallery
364: Forums
365: Photo Gallery
366: Forums
367: Forums
368: Forums
369: Photo Gallery
370: Forums
371: Forums
372: Forums
373: Forums
374: Forums
375: Forums
376: Forums
377: Forums
378: Forums
379: Forums
380: Forums
381: Photo Gallery
382: Forums
383: Photo Gallery
384: Forums
385: Forums
386: Forums
387: Forums
388: Forums
389: Forums
390: Home
391: Forums
392: Photo Gallery
393: Forums
394: Forums
395: Forums
396: Forums
397: Forums
398: Photo Gallery
399: Forums
400: Photo Gallery
401: Forums
402: Forums
403: Forums
404: Forums
405: Forums
406: Home
407: Forums
408: Forums
409: Photo Gallery
410: Forums
411: Photo Gallery
412: Forums
413: Forums
414: Photo Gallery
415: Photo Gallery
416: Forums
417: Forums
418: Forums
419: Forums
420: Forums
421: Forums
422: Forums
423: Home
424: Forums
425: Forums
426: Forums
427: Forums
428: Forums
429: Forums
430: Forums
431: Forums
432: Photo Gallery
433: Forums
434: Photo Gallery
435: Forums
436: Forums
437: Photo Gallery
438: Forums
439: Forums
440: Forums
441: Forums
442: Forums
443: Forums
444: Forums
445: Forums
446: Forums
447: Forums
448: Forums
449: Forums
450: Photo Gallery
451: Photo Gallery
Forums › Marker Talk › Problem/Tech forum :: Archives › Freestyle won't fire, pressurize and leaks :: Archived
tippett
PostPosted: Wed Mar 14, 2007 12:12 am    Post subject: Freestyle won't fire, pressurize and leaks
I have a completly stock Gen 1 freestyle that will not hold pressure and when air is applied it leaks everything out the barrel. I have checked and relubed every oring and I am at a complete loss.
Thanks
tdopb
PostPosted: Wed Mar 14, 2007 1:11 am    Post subject: Re: Freestyle won't fire, pressurize and leaks
check your regs
i kill people... lots of people.... and maybe eat them too
True paintballers love boobs. If you are a true paintballer put this in your sig.
tippett
PostPosted: Wed Mar 14, 2007 1:18 am    Post subject: Re: Freestyle won't fire, pressurize and leaks
I have i can't even get my gauge to read that it is holding any pressure as soon as i start to turn the hpr in it leaks.
Doc
PostPosted: Wed Mar 14, 2007 12:55 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
There are a few possibilities for that problem.
A good start would be to carefully disassemble and clean and lube up the LPR and HPR. Also, clean and lube the bolt assembly.
I'm not all that familiar with FSs but if the LPR is not putting out any pressure, I believe air will just leak out the bolt.
I'd suggest following the manual as far as setting up the HPR and LPR. It requires gradual adjustments.
I'd suggest starting with the HPR at zero pressure and the LPR adjusted so that it will output some pressure as soon as the HPR let's air through. As you gradually increase the HPR pressure, adjust the LPR pressure as well so that that bolt will cock back enough to clear the feedtube.
This should get you started.
Cheers
Lion's Pride www.lionspridepaintball.com
CPPA #1278
B2K4 PDS, Vapor Valve, AKA Sidewinder, AKA SCM 3, 2k7 Chaos
2k3 Black BKO, Modified stock Valve, AKA Mitey Max, Zenitram BKO ASA adaptor, Palmer Stabilizer/Micro-rock, 2k4 Chaos
06 SGM WRX Wagon
tippett
PostPosted: Wed Mar 14, 2007 5:12 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
Thanks Doc, I tried all that and still nothing. The problem I am experiencing is such that when I air the gun up it does not have hold any pressure and the air goes straight through the gun and out the barrel. I have tired airing it up with the LP all the way in all the way out in the middle nothing works. I have taken apart both the LPR and HPR regreased and put it all back together twice. I have also cleaned and lube the bolt and firing chamber but still nothing the air just runs right through the gun. This is quite frustrating.
Thanks again for any help.
Tippett
Doc
PostPosted: Wed Mar 14, 2007 8:46 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
Sounds almost like the LPR is either not getting any air or is not letting any air through to cock the bolt. Or, the Low pressure air passage from the LPR to the solenoid, to the bolt assembly, is blocked.
When you air up, will adjusting the LPR make any difference in what the bolt is doing? (ie. as the LPR pressure is adjusted up, the bolt should gradually get cocked back.
CPPA #1278
06 SGM WRX Wagon
tippett
PostPosted: Wed Mar 14, 2007 11:15 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
I would say no however I took the back off again and pushed the bolt forward with the LPR all the way in and the hpr backed off competly I slowly start to add air and I could hear the soleniod clicking and pushing the air but the bolt remained forward and the gun did not recock, so I started to back off the LPR and the bolt let out a pop and air began to leak out fast again. However, when the bolt is back before appling I can't get any response other than air rushing out the barrel.
Thanks
Doc
PostPosted: Wed Mar 14, 2007 11:52 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
Thanks
You may already know this but the LPR actually is what cocks the bolt back. Instead of backing off the LPR in the above process, did you try increasing the LPR pressure? It sounds like as you "back off the LPR" and the bolt lets out a pop, the bolt is slamming forward and stays forward thus allowing the air to rush out as it's supposed to do.
If you max out the LPR and the bolt still isn't cocking back, then something is wrong with the LPR system.... could be the LPR or somewhere along the air passage.
CPPA #1278
06 SGM WRX Wagon
tippett
PostPosted: Thu Mar 15, 2007 12:09 am    Post subject: Re: Freestyle won't fire, pressurize and leaks
I couldnt go any further in with the LPR that is why I backed out, also I have tried another stock reg (I have a gen 2 in pieces in my basement) and an STD LPR nothing with either of those LPRs connected. I was aware that the LPR cocks the bolt I still cant get the bolt to cock. IF at all possible could u help me narrow down the air pathways.
Thanks
Doc
PostPosted: Thu Mar 15, 2007 4:48 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
Hmm.... Unfortunately, I'm not familiar with the exact air passages in the FS. I'm afraid this is as far as I can take it. You've done what I would've recommended already.... which is to swap out the LPR with something else as possibly, the LPR is faulty. I think you've proven that it's downstream from the LPR.
The only other thing that I can think of is to make sure none of the hoses are kinked.
Sorry. I don't know how else to help.
CPPA #1278
06 SGM WRX Wagon
Blocks and steals are pretty good
Last post by Skyzhay in Freestyle General Talk on Sep 07, 2021 at 08:33:50
Madden NFL 22: Tight End Ratings
Last post by Skyzhay in Paintball talk on Sep 07, 2021 at 08:32:38
Really appreciated the group facets of dungoneering
Last post by Skyzhay in Off Topic on Sep 07, 2021 at 08:31:33
Chaussures de Nike KD
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:08:23
Converse All Star Precio
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:05:32
Nike Air Foamposite Shoes
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:02:18
Nike Air Max 1 Schoenen
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:58:34
Prodotti Adidas Nizza
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:52:24
Chaussures de Nike Air Vortex
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:47:18
Marlboro Cigarettes Online thirty minutes
Last post by sellcigarette in Paintball talk on Aug 23, 2021 at 09:36:02
