Visitors: 76
Total: 76
35: Your Account
62: Home
65: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › lpr problem on my b2k4 :: Archived
psychomantis125
PostPosted: Sat Mar 17, 2007 3:24 pm    Post subject: Re: lpr problem on my b2k4
it seems to have the same problem with my tippman, a few shots and then stops....how should i deal with this problem?
PostPosted: Sat Mar 17, 2007 3:31 pm    Post subject: Re: lpr problem on my b2k4
try not screwing it in all the way, just until you hear air enter the marker.
psychomantis125
PostPosted: Sat Mar 17, 2007 3:38 pm    Post subject: Re: lpr problem on my b2k4
ive tried many differnt "screwing" attempts , but normally i screw it in till the bolt moves back
kruppy
PostPosted: Sat Mar 17, 2007 5:08 pm    Post subject: Re: lpr problem on my b2k4
screw in further... the pin on the tank isn't getting pushed in far enough... What kind of tank is it? and what Type of setup are used on both guns??
2k1 MacDev Sonic Autococker
- E-Bladed (undrilled)
- Shocktech Feedneck
- 15* Asa
psychomantis125
PostPosted: Sat Mar 17, 2007 5:30 pm    Post subject: Re: lpr problem on my b2k4
its a dye throttle air system, the tippy is just basic stock beside a check it drop foward, so is the b2k4 but with a uni mount instead....OK i know this is confuseing and i thank you for all you help but things just got a bit more confuseing for me...so i know i said it didn't work on the tippy,but i screwed it in as much as i could and turn the knob all the way and got it to work fine with the tippy, so i assume it my uni mount that is messed up. i took off my mounts and connected my tippy mount to my b2k4 and it won't work...so i think we can safely say the mounts and tank are fine
kruppy
PostPosted: Sun Mar 18, 2007 11:05 pm    Post subject: Re: lpr problem on my b2k4
OKay... then onto stage 2.... Check ALL your fittings to make sure there not backed in so far that pressure can't get through and take your regulator apart and clean it and relube it... you can find schematics and manuals on how to do that on this site or on icd's home page... Let me know how that goes.. if it sill occurs then we got issues but get back to us first after that..
- 15* Asa
psychomantis125
PostPosted: Wed Mar 21, 2007 8:34 pm    Post subject: Re: lpr problem on my b2k4
good news, thank you all for your help, i really apperciate it, but iono everything we was trying didn't work so i decided to just go buy a new cp reg and that fixed it, im sure there is a way to fix the problem without buying the new reg but im not that pro with my gun yet so thanks tho, now i gots a new reg =)
immortal_clown
PostPosted: Wed Mar 21, 2007 10:05 pm    Post subject: Re: lpr problem on my b2k4
Grats , but keep your stock reg and do your best to fix the problem. No better way to learn about your gun then practicing fixing a spare part Smile
These are just some examples
