Latest: joker4pb
Overall: 7905
Visitors: 171
Total: 171
22: Your Account
82: Home
93: Home
95: Home
128: Home
152: Your Account
166: Photo Gallery
Forums › Marker Talk › Problem/Tech forum :: Archives › Gun not Workin pressures up but doesnt fire :: Archived
tinm4n
PostPosted: Sat Jul 14, 2007 9:08 pm    Post subject: Gun not Workin pressures up but doesnt fire
Well guys i just got a used b2k4 and ive done about everything i can to make it work i just dont know what the problem is. i have put a diffrent reg on it changed the manifold, and made sure all orings are fine. i know that the lpr is not bad and i know the board isnot bad. it take air in but i cant get it to fire. ive tryied my stock board and nox board. i dont know if the person i bought it from was missing a peice in side or not but does and one have a detailed scimatic of the gun so i can make sure all the parte are their. oo and their is nothing wrong with the lpr. the cockin bolt works fine. but if any buddie can give me advice that would be great. Thanks for takin ur time and reading.....
PostPosted: Sat Jul 14, 2007 10:00 pm    Post subject: Re: Gun not Workin pressures up but doesnt fire
you try a new battery? what's the LED doing? eyes on or off?
tinm4n
PostPosted: Sat Jul 14, 2007 11:17 pm    Post subject: Re: Gun not Workin pressures up but doesnt fire
yeah battery is fine brand new..
tinm4n
PostPosted: Sun Jul 15, 2007 12:03 am    Post subject: Re: Gun not Workin pressures up but doesnt fire
i can get the reg to air up but to 250 and no leaks.. but idk is the bolt supposed to be all the way forward... and is the lpr spring supposed to be tighter then the piston rod spring... i have a good battery and a good manifold and led works so yeah plz.... help me
tinm4n
PostPosted: Sun Jul 15, 2007 2:04 am    Post subject: Re: Gun not Workin pressures up but doesnt fire
well i sorta got that fixed but i have another probleme, well my bolt fires once but it gets stuck forward so yeah any one plz help me.... if u can....well thanks... o yeah i have no eyes...
tinm4n
PostPosted: Sun Jul 15, 2007 2:05 am    Post subject: Re: Gun not Workin pressures up but doesnt fire
PostPosted: Tue Jul 17, 2007 1:44 pm    Post subject: Re: Gun not Workin pressures up but doesnt fire
If you go to the ICD website, they have a technical support section. You can down-load an exploded view of the marker. They also have a cut-away view as well. When your bolt goes forward and stays, is it dumping air down the barrel? If not, what is the gauge reading? No sound of leaks? Have you cleaned the ram? Does the solenoid make an audible "click" every time you activate the trigger?
If you get tired of messing with and and decide to get rid of it, let me know!
PostPosted: Tue Jul 17, 2007 3:14 pm    Post subject: Re: Gun not Workin pressures up but doesnt fire
Battery. I know he said it was fine, but define "fine" - I"ve had brand-new batteries out of the packaging that are dead.
Go buy a new battery, try it out.
emopunker2004
PostPosted: Tue Jul 17, 2007 4:51 pm    Post subject: Re: Gun not Workin pressures up but doesnt fire
go buy a GOOD BRAND NEW BATTERY like durracel or energizer
feedback- www.icd-owners.com/htm...ic&t=10139
SKI008
PostPosted: Tue Jul 17, 2007 6:24 pm    Post subject: Re: Gun not Workin pressures up but doesnt fire
Make sure your bolt hasn't swollen if you have a delrin one. Last weekend I was having similar problems and it was because my bolt had swollen to the point where it wouldn't cycle; it was too tight in the body. (Was a real pain to get out also).
I would have an avatar, but I can't make any of my pictures small enough.
OPEN FOR BUSINESS - New "FURIOUS" Harnesses
Last post by quadpod in ICD Gear Forum on Jul 14, 2018 at 21:32:23
Last post by THE_Hulk in ICD Gear Forum on Jul 14, 2018 at 18:32:54
Nameless ICD parts Store
Last post by joker4pb in ICD Gear Forum on Jul 13, 2018 at 23:02:18
ISO/WTB freestyle wiring harness
Last post by joker4pb in ICD Gear Forum on Jul 08, 2018 at 23:51:05
Last post by glaman5266 in ICD Gear Forum on Jul 01, 2018 at 12:46:11
Wtb Indian creek design solenoid 982030
Last post by Tjone in ICD Gear Forum on May 30, 2018 at 21:33:32
Last post by lasoyapro in Paintball talk on May 25, 2018 at 18:38:48
Last post by Walkertl in ICD Mech Markers on May 15, 2018 at 19:06:39
Last post by 63VDub in ICD Gear Forum on May 02, 2018 at 17:01:55
