Visitors: 128
Total: 128
75: Home
91: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › PDS switch :: Archived
PDS switch
D_WeBB
PostPosted: Thu Sep 27, 2007 10:06 pm    Post subject: PDS switch
i recieved my gun today from greg and the pds switch is loose. the entire
thing. the screws wont even screw it to secure it. what should i do?
T2'd B2K4 w/ PDS - NOX Board, Ebay Valve, CP HPR, Sonic LPR
SteveIsGr8
PostPosted: Thu Sep 27, 2007 10:17 pm    Post subject: Re: PDS switch
Take a pair of pliers and squeeze the area on the switch that the screws go into (on the flat side). Then see if the screws will hold. If not, then bend the tabs a tiny bit or twist them. What you're trying to do is get the hole to deform a bit so the screws will have something to hold. If they will snug down, then either add loctite or superglue to the threads. Also, don't crank the screws hard. If nothing works, then you can change out the switch.
Steve
SteveIsGr8 is a cool guy because I said so. - Spitlebug
D_WeBB
PostPosted: Thu Sep 27, 2007 10:49 pm    Post subject: Re: PDS switch
Thanks alot Steve. Ill respond here with what happens.
Goldie
PostPosted: Thu Sep 27, 2007 11:34 pm    Post subject: Re: PDS switch
Chances are loctite or some superglue are your best bet for a quick fix. Trying to smash the switch will work, but it's VERY easy to smash the switch completely. I'd look for another alternative first.
D_WeBB
PostPosted: Fri Sep 28, 2007 12:36 am    Post subject: Re: PDS switch
Thanks for the additional input Goldie. I think i'm going to play it safe and use some crazy glue.
