Visitors: 67
Total: 67
09: Your Account
38: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › chopping still.. :: Archived
chopping still..
Jarhead
PostPosted: Wed Dec 31, 2003 6:17 pm    Post subject: chopping still..
ive tried everything.. setting my regs. i have a vapor bolt no blow back. have an egg with y board(which i cant even outshoot on my dads angel). i cant go through half a hopper without chopping. what could be causing this? Neutral
BKOfreak05
PostPosted: Wed Dec 31, 2003 7:47 pm    Post subject:
What i would do is just break down the entire gun and clean and re-grease everything. When i first got my gun, i bought it used, it would chop like crazy...so i just cleaned it real good and greased everything and it works like a dream. So try that and if you still chop make sure that if you have a 2k3 bko you check your detent cuz your egg could be double feeding.
Jarhead
PostPosted: Wed Dec 31, 2003 8:21 pm    Post subject:
alright.. il reinforce the detent with macroline and clean it.. hopefully that will work.. thanx for the help
BKOfreak05
PostPosted: Wed Dec 31, 2003 11:42 pm    Post subject:
by the way one last thing....make sure you clean your regs really good. I went to play one day in november and my effeciency was horrible, i would have crazy pressure spikes and bad accuracy. Some jumps of 100 fps or more on the chrono. I didn't even get to play on the field that day. I was so frustrated that i was ready to give up paintball completely. But when i got home i calmed down and decided to take apart the whole gun and see if i could fix it. I eventually found a very small piece of plastic or rubber in my hpr! To this day i haven't found out where it came from but it fixed all my consistency problems. So when you're cleaning make sure you're in a clean area so no small object can find its way into your hpr or any part of your marker...trust me....it will cause more problems than you think. So keep a sharp eye while your cleaning and always play safe...you got two eyes...i don't think you'd be happy with just one!!
Jarhead
PostPosted: Sat Jan 03, 2004 11:56 am    Post subject:
thanx for the help man it worked Very Happy
BlAstInwItbk0s
PostPosted: Sat Jan 10, 2004 7:24 pm    Post subject:
how do u do the thing with the macroline or should i just get cocker dentents Rolling Eyes
PostPosted: Sat Jan 10, 2004 10:07 pm    Post subject:
PatrickLee had a good pic of one.... search the threads. It's kinda hard to describe.
Also, the cocker detents only fit on the early BKOs as they were the ones with cocker detents... obviously. The newer BKOs do not have cocker detents.
Cheers
