Latest: major_movit
Overall: 7915
Visitors: 53
Total: 53
15: ICDU
16: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › Wiring Help :: Archived
Wiring Help
darkseedx
PostPosted: Wed Mar 12, 2008 9:00 pm    Post subject: Wiring Help
All right! I need someone to teach me how to wiring a wiring harness. Lets say that I have all the doodads attached to the wires... (microswitch, noid, etc} but how do I attach them into the disconnect? Also both the noid wires came out of the disconnect but they are both blue...
Sneaky
PostPosted: Wed Mar 12, 2008 10:45 pm    Post subject: Re: Wiring Help
www.icd-owners.com/htm...m=21&pos=1
check here
darkseedx
PostPosted: Thu Mar 13, 2008 8:39 pm    Post subject: Re: Wiring Help
I dont quite know how to get the wires in the plug.... Embarassed They pulled out but left the metal thingie inside the plug.
PostPosted: Fri Mar 14, 2008 6:15 am    Post subject: Re: Wiring Help
Use a pin to lift the retaining tabs and push the little connector inserts out the top of the plug.
Jdubau55
PostPosted: Fri Mar 14, 2008 6:35 pm    Post subject: Re: Wiring Help
This might help
Chances are you will need new crimp terminals. Let me guess....you don't have a crimp tool for crimps this small??
darkseedx
PostPosted: Fri Mar 14, 2008 9:50 pm    Post subject: Re: Wiring Help
Well heres a problem. The electronic specialists that I sent it into get fixed teh first time... soldiered the solonoid wires into the sockets.... These are the guys that everyone in town sends their electronics in to get fixed... hummmm
PostPosted: Fri Mar 14, 2008 10:28 pm    Post subject: Re: Wiring Help
What the hell. You *always* pull the terminals out if the wire pulls off...
Jdubau55
PostPosted: Fri Mar 14, 2008 11:02 pm    Post subject: Re: Wiring Help
I meant if the wire was still in the terminal crimp.
So.....the wires didnt pull out of the crimps, but broke off???
darkseedx
PostPosted: Fri Mar 14, 2008 11:41 pm    Post subject: Re: Wiring Help
the wires broke off from the solonoid because the dudes who "Fixed' it soldiered them in. The other wires just pulled out so I should be able to fix those. I was trying to remove my microswitch to change the grip frame to a lovely OTB but the pins just wouldn't come out. So after smashing at them for 2 hours I finally got them out but most of the wiring came loose from the disconnect {funny tho the microswitch wires are fine}
Jdubau55
PostPosted: Sat Mar 15, 2008 5:55 pm    Post subject: Re: Wiring Help
Pics would help
