Overall: 7911
Visitors: 120
Total: 120
78: Home
93: Home
Forums › General › Paintball talk :: Archives › Tank Q's :: Archived
Tank Q's
viper588
PostPosted: Tue May 06, 2008 1:02 am    Post subject: Tank Q's
Hey guys, i got a Crossfire 68/3000 steel tank in a trade...i have a crossfire 48/3000 and i was under the assumption that the 68/3000 would be bigger and hold more air. The tanks are basically the same size and the cover for the 48 fits perfect on the 68...will the 68 hold more air? just a little confused cause i thought since one is 48ci and the other is 68ci the 68ci would be noticeably bigger. Thanks
PostPosted: Tue May 06, 2008 3:32 am    Post subject: Re: Tank Q's
The 68ci tank should be noticeably larger than the 48ci. The ci refers to the volume (aka larger) and the psi is just what it is rated to hold.
viper588
PostPosted: Tue May 06, 2008 10:33 am    Post subject: Re: Tank Q's
Here are some pics of the tanks the 68 looks a little bit wider and a little bit shorter but if its 68ci wouldnt it be 20ci larger overall? just looks almost the same to me lol Thanks for all comments
PostPosted: Tue May 06, 2008 3:22 pm    Post subject: Re: Tank Q's
The 47ci tank is aluminum and the 68ci tank is alloy steel.
More aluminum is required to withstand the pressure per internal square in than steel.
What I mean is that the 68 will have thinner walls than the 47 since the steel is structurally stronger than the alluminum. That internal volume on the 47 will be less than the 68 but the outside might appear the same. Also, the 47 tank is likely heavier than the steel because of the additional material.
Here is a link to a thread that may help further explain this.
www.automags.org/forum...hp?t=27355
Hope that is helpful.
viper588
PostPosted: Tue May 06, 2008 6:11 pm    Post subject: Re: Tank Q's
Thanx that helps alot =) was just kinda curious lol =P
PostPosted: Tue May 06, 2008 10:50 pm    Post subject: Re: Tank Q's
That looks about right. Even though the tank is shorter, the width will more than make up for that.
viper588
PostPosted: Thu May 15, 2008 12:05 am    Post subject: Re: Tank Q's
Hey guys have another question but figured i wouldnt start a new thread.. i found a website selling a 68/45 carbon fiber tank without the regulator on it...is a regulator from a 48/3000 compatible with a 4500 tank? thanks
christhered
PostPosted: Thu May 15, 2008 1:07 am    Post subject: Re: Tank Q's
only if you fill the tank to 3000 and no more.
AB Freestyle Pro
Bob Long Darq Marq
Bob Long Vice
Check BST for my huge rare bushy part out sale
viper588
PostPosted: Thu May 15, 2008 1:27 am    Post subject: Re: Tank Q's
would the only prob be the burst discs or are there other things as well?
PostPosted: Thu May 15, 2008 9:18 am    Post subject: Re: Tank Q's
As I recall, its the reg itself not just the burst discs. I would say ultimately, not to risk it, you don't want it to blow up Smile
Last post by R2Ranger in Bushmaster General talk on Feb 22, 2019 at 22:00:55
