Visitors: 70
Total: 70
22: Home
45: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › Chaos 04 Voltage, Amp and uf questions :: Archived
Go to page Previous  1, 2
pump
I like bukkake!
I like bukkake!
PostPosted: Tue May 27, 2008 10:52 pm    Post subject: Re: Chaos 04 Voltage, Amp and uf questions
hey how do i put them in a series?
also.....does it matter what noid wire i use?
and will i need a resistor or transistor? the guy at Radioshack said i would or i would short out the noid or board....i know nothing
autotriggers for sale
Shocktech B2Ks
NIB Warp Feeds FS
PostPosted: Wed May 28, 2008 3:02 pm    Post subject: Re: Chaos 04 Voltage, Amp and uf questions
I believe to put them in a series, you connect the drain of the first IFR510 to the gate of the second IFR510. It shouldn't short the noid if you are using a pancake noid. A standard 5v noid will blow up though.
forums.parallax.com/fo...15&m=60434
What this shows is a schematic with a resistor but the last post shows that it is not actually required.
Yes the polarity matters on the Humphrey and pancake noids but not on Skinner/Parker noids.
*Edit* Also, an IFR510 is a transistor of a sort....
pump
I like bukkake!
I like bukkake!
PostPosted: Wed May 28, 2008 4:17 pm    Post subject: Re: Chaos 04 Voltage, Amp and uf questions
ah ok will do...........im off to try..........
cross your fingers.....ill burn mine
Shocktech B2Ks
NIB Warp Feeds FS
PostPosted: Thu May 29, 2008 5:41 am    Post subject: Re: Chaos 04 Voltage, Amp and uf questions
Good luck. I can only suggest making a post on the Tinker's Guild to see if they might have some suggestions.
Perhaps try with a stock board first. Wink
pump
I like bukkake!
I like bukkake!
PostPosted: Thu May 29, 2008 5:16 pm    Post subject: Re: Chaos 04 Voltage, Amp and uf questions
i only got a chaos left, i wonder can the chaos get .25 increments if i use the vlink?
yeah i got some good info from Nicad already and im gonna post the pic you made see what he thinks
Shocktech B2Ks
NIB Warp Feeds FS
Page 2 of 2
