Overall: 7911
Visitors: 144
Total: 144
33: Your Account
89: Home
106: Home
130: Home
Forums › General › Paintball talk :: Archives › Pmi 48ci 3000psi leaking, any ideas? :: Archived
PostPosted: Thu Apr 21, 2011 7:57 pm    Post subject: Pmi 48ci 3000psi leaking, any ideas?
bleeds off all the inserted air... I have no idea why. Im takeing it to the shop saturday to possibly get a refund and a better tank. I just dont know much about tanks.
PostPosted: Thu Apr 21, 2011 9:14 pm    Post subject: Re: Pmi 48ci 3000psi leaking, any ideas?
Spary soapy water around the bonnet (the part with the threads). Where the leak is coming from, it will bubbly up. Most leaks are easy to find and fix.
PostPosted: Thu Apr 21, 2011 9:18 pm    Post subject: Re: Pmi 48ci 3000psi leaking, any ideas?
no air... dosent hold it period.
PostPosted: Thu Apr 21, 2011 9:19 pm    Post subject: Re: Pmi 48ci 3000psi leaking, any ideas?
Still, tanks always will have a tiny bit in them. Give it a try.
no joy, jt...
PostPosted: Thu Apr 21, 2011 9:32 pm    Post subject: Re: Pmi 48ci 3000psi leaking, any ideas?
It it won't hold air at all the check valve is bad. This shouldn't be an issue with a new tank though.
Pmi regs are pretty easy, 2 orings and one check valve not much that can go wrong and easy to flesh out issues.
It you got it new just return it and get
Something different,
PostPosted: Thu Apr 21, 2011 9:34 pm    Post subject: Re: Pmi 48ci 3000psi leaking, any ideas?
ok.
PostPosted: Thu Apr 21, 2011 10:48 pm    Post subject: Re: Pmi 48ci 3000psi leaking, any ideas?
It is a steel tank? get rid of it and invest in a carbon fiber tank.
PostPosted: Thu Apr 21, 2011 10:51 pm    Post subject: Re: Pmi 48ci 3000psi leaking, any ideas?
steel, yes. saturday im takeing it up there for a refund. ill have 130 for a tank.
PostPosted: Thu Apr 21, 2011 10:52 pm    Post subject: Re: Pmi 48ci 3000psi leaking, any ideas?
I might have one for you. I will pm you tomorrow night about it.
