Latest: YAz45mmi
New Yesterday: 1
Overall: 7922
Visitors: 179
Total: 179
53: Your Account
104: Home
115: Home
118: Home
166: Home
171: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Just snapped the MI solonoid wire... on good friday... :: Archived
PostPosted: Mon Apr 04, 2011 5:33 pm    Post subject: Just snapped the MI solonoid wire... on good friday...
Just noticed this, the bolt sticks out farther than it should and blocks the ball from feeding, will this correct it self when aired up?
PostPosted: Mon Apr 04, 2011 6:22 pm    Post subject: Re: MI Bko bolt feeding problem.
Well the bolts on the ICD stuff are not adjustable so it should clear the breach. Remember, there is no air forcing the ram/bolt into the open position it is the ram spring. So no, airing up the gun will have no affect on the bolt's open position.
Check to make sure that the bolt pin is actually in the hammer slot and not infront of the hammer.
It is possible (not likely) that the hammer has come unscrewed from the ram shaft. Pretty easy to check this (just take the ram out of the gun).
Finally make sure someone didn't put in some piece of something under the ram cap to keep the bolt from going all the way back. Just remove the ram cap. I actually had to do just this, I installed a small piece of macro to make the bolt sit a bit farther forward as the eyes I milled in the breach were a tad low....but that is really a discussion for another time.
So, just try the above things and see what happens.
PostPosted: Mon Apr 04, 2011 6:29 pm    Post subject: Re: MI Bko bolt feeding problem.
when not aired up the bolt sits all the way open not blocking the breach, when you look down the feedneck the bolt should clear the breach, if not then your pin is probably not seating into the ram and is in front of it.
PostPosted: Tue Apr 05, 2011 12:01 am    Post subject: Re: MI Bko bolt feeding problem.
Fivestring, I think he's got the old square end ram, so he can't pull the cap. Check your pin placement and see if the hammer is unscrewed, as suggested.
PostPosted: Tue Apr 05, 2011 12:35 am    Post subject: Re: MI Bko bolt feeding problem.
screw is locked, pin is lined...
PostPosted: Tue Apr 05, 2011 1:05 am    Post subject: Re: MI Bko bolt feeding problem.
pics would help
PostPosted: Fri Apr 22, 2011 10:08 pm    Post subject: Re: Just snapped the MI solonoid wire... on good friday...
it works with electrical tape but it slides out...
PostPosted: Tue May 17, 2011 7:09 pm    Post subject: Re: Just snapped the MI solonoid wire... on good friday...
Uh, how long does the wire need to be striped for the solder to bond the two wires back together? i have 1/4 an inch both sides.
PostPosted: Tue May 17, 2011 7:24 pm    Post subject: Re: Just snapped the MI solonoid wire... on good friday...
It has to be 3/4 of the O.D of the wire to the 10th power, then subtract the total length of the wire. After you do that, take the I.D of the wire and multiply that by the bonding strength of the tin. Then you will have the length needed... comprende?
adidas online kopen
Last post by YAz45mmi in Calendar of Events on Oct 24, 2020 at 04:06:09
NikeLab Dunk Lux SP Dark
Last post by YAz45mmi in Off Topic on Oct 24, 2020 at 03:59:37
Converse har spillet med
Last post by YAz45mmi in Paintball talk on Oct 24, 2020 at 03:51:39
adidas EQT-Kissen ADV
Last post by YAz45mmi in PRP General Forum on Oct 24, 2020 at 03:45:37
adidas solar glide st 3 rosse
Last post by igo5apzv in Calendar of Events on Oct 22, 2020 at 02:08:20
adidas solar glide st heren
Last post by igo5apzv in Off Topic on Oct 22, 2020 at 02:05:46
adidas solar glide 19 negras
Last post by igo5apzv in Paintball talk on Oct 22, 2020 at 02:02:12
Last post by Tzarector in ICD Gear Forum on Oct 15, 2020 at 13:24:07
new balance 1530 saldi online
puma italia scarpe
