Latest: major_movit
Overall: 7915
Visitors: 302
Total: 302
91: Home
157: Photo Gallery
168: Photo Gallery
177: Photo Gallery
183: Photo Gallery
190: Photo Gallery
193: Photo Gallery
195: Photo Gallery
197: Photo Gallery
202: Home
210: Photo Gallery
221: Photo Gallery
224: Photo Gallery
226: Photo Gallery
228: Photo Gallery
234: Photo Gallery
238: Photo Gallery
239: Photo Gallery
241: Your Account
242: Photo Gallery
243: Photo Gallery
247: Photo Gallery
253: Photo Gallery
262: Photo Gallery
263: Forums
267: Photo Gallery
271: Forums
272: Forums
273: Forums
274: Forums
275: Forums
277: Forums
279: Photo Gallery
280: Photo Gallery
281: Photo Gallery
282: Photo Gallery
283: Forums
284: Photo Gallery
285: Forums
286: Forums
287: Forums
288: Photo Gallery
289: Forums
290: Forums
291: Forums
292: Forums
293: Photo Gallery
294: Photo Gallery
295: Forums
296: Forums
297: Forums
298: Forums
299: Forums
300: Photo Gallery
301: Forums
302: Forums
Forums › Marker Talk › Problem/Tech forum :: Archives › BKO Extreme, somethings wrong with gassing it :: Archived
jon123
PostPosted: Sat Oct 30, 2004 2:46 pm    Post subject: BKO Extreme, somethings wrong with gassing it
hi i just got a bko extreme and i am really new to ICD and bko, put my tank on my gun and i adjusted the hpr or w/e that ison my front grip, when i turned it up it stared hissing somewhere up by the bolt or belowit, so i turned it down until it stopped, then i shot and there wasnt enough pressure for it to shoot the ball straight, it was doing rainbow shots, how do i stop it from hissing? and making it be able to shoot harder so the balls go striaght , by the way, i turned the screw on my fore grip up and i guess i went to far cuz when i gassed my gun the gauge went way overboard and now it wont go back even after i took off mytank, any idea on how to fix the gauge too? plz help someone because i just spent alot of money on this gun and i really want to get it working. btw its all stock.
PostPosted: Sat Oct 30, 2004 5:17 pm    Post subject:
Hi John.
I'm guessing you didn't take a read through the manual first...
a) if your gauge won't go back down.. you've blown it, and it can't be repaired, it will need to be replaced.
b) once you replace your gauge.. back that little set screw in the bottom all the way out, and back out the screw on the LPR as well - the LPR is the round thing right below where the barrel screws in.
c) Screw in your air tank, and start screwing in the set screw on your HPR - the tube thing pointing downwards - until the gauge reads abou 225-250 psi.
d) start screwing in the adjustment screw on your LPR until you hear that hissing start again. When you do, turn the adjustment screw BACK by a quarter to a half a turn.
e) put your hopper on, and start shooting paint across a chronograph, using the set screw on your HPR to adjust your velocity until you're shooting around 275 feet per second.
That should do it.
You can, of course, just read the manual and get all the same information in there as well.
BKO_Ballistics03
PostPosted: Sat Oct 30, 2004 5:19 pm    Post subject:
Look under the barrel. Theres a thing there called the LPR. Turn it out all the way. Now put your HPR to about 270-300 then slowly turn up the LPR till the gun barely cycles. From there keep adjusting it up till you reach your desired speed. If it starts leaking again then just turn it down a bit. If its not that then just try taking a clearing shot. Thats what mine needed.
HK Affiliate
Front player for hire
Proud member of the anti-pants revolution
Gun setup:
Black 2k4 BKO
Cp 2 piece barrel
CP Rail
Halo Reloader B
Crossfire LP tank
BKO_Ballistics03
PostPosted: Sat Oct 30, 2004 5:21 pm    Post subject:
opps beat me to it
HK Affiliate
Gun setup:
Black 2k4 BKO
Cp 2 piece barrel
CP Rail
Halo Reloader B
Crossfire LP tank
