Visitors: 296
Total: 296
03: Your Account
114: Home
120: Home
123: Home
145: Home
153: Home
154: Home
155: Home
156: Home
167: Home
169: Home
189: Photo Gallery
196: Home
197: Home
198: Home
207: Photo Gallery
210: Home
211: Photo Gallery
212: Photo Gallery
213: Photo Gallery
219: Your Account
226: Home
232: Photo Gallery
244: Home
248: Home
262: Photo Gallery
263: Forums
267: Forums
271: Forums
272: Forums
273: Forums
274: Home
275: Your Account
276: Photo Gallery
277: Forums
279: Forums
280: Forums
281: Forums
283: Forums
285: Photo Gallery
286: Forums
287: Forums
288: Forums
289: Forums
290: Home
291: Forums
292: Forums
293: Photo Gallery
294: Forums
295: Forums
296: Forums
Forums › Marker Talk › Problem/Tech forum :: Archives › freestyle leak :: Archived
freestyle leak
Bdawg
PostPosted: Wed Apr 13, 2005 3:23 pm    Post subject: freestyle leak
my freestyle is leaking out of the solinoid area don't know why. but i don't feel like sending it back to icd for a second time. any one know what i can do?
Thndr_strck
PostPosted: Wed Apr 13, 2005 10:59 pm    Post subject:
Check your LP reg, maybe it's turned in too far ?
Bdawg
PostPosted: Fri Apr 15, 2005 2:47 pm    Post subject:
did that
ichibansf
PostPosted: Sat Apr 23, 2005 11:15 am    Post subject:
I have the same problem. It gets worse the higher you go on the HPR, even if the LPR is set to be as far out as possible (STD LPR). So when I set the HPR lower (down to 220psi) the leaking stops, but I don't have enough air to push the ball very far. Any ideas? Help, Greg? It isn't a very big leak, just a slight hisssss.
There's no leaking from the LPR, it's definately from the solenoid area, as tested via the cigarette smoke method...
Dblock
PostPosted: Fri Apr 29, 2005 1:05 pm    Post subject:
i have the exact same problem its a very little hiss
04 Freestyle gen 2 68/3000
blank187
PostPosted: Thu Jun 23, 2005 11:26 am    Post subject:
check ur LPR for any types of o-ring damage, the reason ur solenoid is leaing is cause the LPR isnt regulating.. just check it, and if that doesnt work tighten the screws from your solenoid and manifold, lube everything, and if that doesnt work... CALL ICD
bushyman06
PostPosted: Thu Jun 23, 2005 2:18 pm    Post subject:
check/lube the gaskets on the solinoid(by unscrewing the solinoid manifold from the body, they will be on the top)
and also try tightening all the solinoid screws.
CJLOVI
PostPosted: Sat Jun 25, 2005 9:22 am    Post subject:
Replace the o-rings in the bolt. Thought my solinoid was leaking. Found it to be the #06 o-ring in the bold. "TINY" scratch wrecked havoc on the air leak.
View user's profile Send e-mail Visit poster's website Yahoo Messenger Photo Gallery
