Visitors: 79
Total: 79
Forums › Marker Talk › Problem/Tech forum :: Archives › NEW BKO LEAKING>>HELP! :: Archived
stormcrow23
PostPosted: Mon Nov 10, 2003 8:37 am    Post subject: NEW BKO LEAKING>>HELP!
The first time I took my BKO to the field it worked great..But...over the weekend I was practicing in my back yard, trying to shoot as fast as possible, and after shooting a couple of hoppers, I detected a loud leak. It seems to be coming from the top of the grip frame, close to the on/off switch. Should I send it back? Or does it sound like an easy fix? Please keep in my mind I am not too familiar with the BKO.. THANKS.
abarnhar
PostPosted: Mon Nov 10, 2003 9:04 am    Post subject:
You'll have to take it apart and isolate the leak. Detatch the grip frame and tray from the main body by removing the four allen-headed screws on the tray. Then, gas up your gun and feel/listen for the leak. Post back and tell us where it is at exactly (by the solenoid, the blue line where it attaches to the ram, etc) and we'll help you out!
Can't think... n00bs will get me
stormcrow23
PostPosted: Mon Nov 10, 2003 11:41 am    Post subject: Whats the tray?
What's the tray and if I take it apart will it void my warranty?
NKP82
PostPosted: Mon Nov 10, 2003 12:42 pm    Post subject:
Taking the tray off the gun should not void the warrenty, other wise then I am screwed too. Might be the noid, just tighten the two screws that hold the noid to the ram assembly, but dont tighten it to much though. If you do over tighten you might damage something and then thats an other problem for you to take care of.
>12" Freak Barrel System
>14" J&J Performance Ceramic
>Dye Stickies 3
>CCM Clamping Low-rise
>AKA Sidewinder
>MacDev Red Valve
>Evlution II w/ Z Board
PostPosted: Mon Nov 10, 2003 2:50 pm    Post subject:
Your solenoid is loose, just loctite it on there or use nail polish and you should be good.
Bko_monkey
PostPosted: Mon Nov 10, 2003 2:59 pm    Post subject:
Nail polish!!!???????
PostPosted: Mon Nov 10, 2003 3:30 pm    Post subject:
It works. I was told by Goldie and i trust him.
stormcrow23
PostPosted: Tue Nov 11, 2003 6:41 am    Post subject: Whats the tray? Whats the NOID?
Could someone please explain in laymans terms what I need to do here? Please remember that I just upgraded from a 32* Rebel to the BKO, therefore I am not familiar with the parts associated with my new marker.
Thank you kindly.
PostPosted: Tue Nov 11, 2003 7:22 am    Post subject:
take everything apart.
you see the solenoid (has 2 wires coming out of it and is small grey and plastic, attached to the underbelly of the ram)
unscrew those 2 on the bottom of the solenoid
tahe the solenoid off
put some loctite or nail polish on the end of the screw, make sure not to get any on the gasket (flexy rubbery part)
re screw it back in and screw it on tight
let it dry overnight
there you go
BenBKO
PostPosted: Tue Nov 11, 2003 7:50 am    Post subject:
also dont forget your local paintball feild pro shops. they should have someone that could fix it for you or help more explain things about your gun.
ryan 314 ratm: your gun is like a retarded kid, but now has a chance to compete in the special olympics.
2000 spyder compact
brass eagle mask
gravity feed hopper
soon to come...
barrel plug
View user's profile Send e-mail AIM Address Yahoo Messenger
