Visitors: 140
Total: 140
04: Your Account
12: Your Account
106: Home
118: Home
119: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › B2k4 vribrates :: Archived
B2k4 vribrates
bushmasterpro
PostPosted: Sat Feb 18, 2006 9:48 am    Post subject: B2k4 vribrates
Igot a b2k4 for xmass and i used it about 10 times at the local indoor field and last weekk my gun jamed i did not havea clue what the problem was so i took it to the local shot for them to hvae a look at it and he looked it over and the gun was fine i took it home and started shootign it and when i shoot the gun vribrates for a few secound after each shot any one got an idea i taken the lpr and the ram out to see if it was the springs but it fells liek spring vibrating but the springs arnt loose or any thign i put it all back togeather and it still virbrates and one have any ideas that migth fix it reply soon
.. torny in 1 week
PostPosted: Sat Feb 18, 2006 11:39 am    Post subject: Re: B2k4 vribrates
I got a b2k4 for xmas, and i used it about 10 times at the local indoor field. Last week my gun jammed. I did not have a clue what the problem was, so i took it to the local shop for them to have a look at it. He looked it over and the gun was fine, so i took it home and started shooting it. When i shoot the gun vibrates for a few seconds after each shot. Does any one got any ideas? i have taken the lpr and the ram out to see if it was the springs because it feels like spring vibrating, but the springs aren't loose or anything. i put it all back togeather and it still virbrates, so does any one have any ideas that might fix it? Please reply soon and thank you for your help
Also, I need to figure this out, as I have a tourny in 1 week.
<edited for punctuation, spelling, grammar, and general good form Smile >
PostPosted: Sat Feb 18, 2006 11:43 am    Post subject:
what is your complete setup? is it bone stock? what are you using for your HPR? What tank are you using?
I would suggest tearing down your HPR, cleaning and lubing it. Are you noticing any pressure fluctuation on your guage from shot to shot?
How did your marker jam?
Specifics would help.
bushmasterpro
PostPosted: Sun Feb 19, 2006 7:48 am    Post subject:
um i using stock every thing i got a 47/300 crossfire tank i was playing agame and i was shootignaround a bunker and my gun jsut stop shooting and start clicking like when u shoot ur gun with no air on it when it turned on the ram was stuck backwards i had to push the bolt pin foward hard to get it to come free
PostPosted: Sun Feb 19, 2006 10:28 am    Post subject:
Hmmm, I dunno about that, it almost sounds like your niod hung, but that's as far as I can go. I'm not a noid expert. I would clean and Lube your HPR and try a new battery and see how it does then.
handyandy
PostPosted: Sun Feb 19, 2006 6:13 pm    Post subject:
im not sure either, but it sounds like the noid to me. the way you described it with the vibration after each shot, it sonds like the noid is staying on too long causing a vibration as it tries to push the ram back.
it could be the noid or the board. but more likely the noid. you should also take appart your lp reg clean and relube it and see if that helps.
good luck
Andy
Selling all my gear, check out the BST
BTW I'm dyslexic... I know I cant spell.
Big_Mac
PostPosted: Mon Feb 20, 2006 7:00 am    Post subject:
It sounds like your LPR is set too high. What is your HPR set at (the gauge on the side of the marker)? Adjust your LPR according to the manual (unless you have an LPR gauge tool).
Is your HPA tank carbon or aluminum? Aluminum tanks can 'ring'...which could be your 'vibration'...particularly if you have your LPR too high.
Stupidity Kills
TheArtist
PostPosted: Mon Feb 20, 2006 8:32 am    Post subject:
Make sure the regs are lubricated, then set your hpr to about 250 and reset your lpr. When shooting the gun, watch your hpr and set if it recovers quickly, if not relube it. Also make sure you are not choking at the asa. What ever you do. do not take the noid apart.
Painting kids is just a hobby<br />urbanwarfare1.com
