Visitors: 74
Total: 74
54: Home
74: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › reg or low pressure :: Archived
reg or low pressure
foxygrandpa215
PostPosted: Wed Apr 14, 2004 9:18 am    Post subject: reg or low pressure
hey i was hearing that i should eather get a low pressure tank or a new reg...does anybody have any suggestions on which one?
View user's profile Visit poster's website AIM Address MSN Messenger
bagkek
PostPosted: Wed Apr 14, 2004 10:19 am    Post subject:
What reason would you need either one of these? What is your current gun setup? and is there a problem that you are having that caused that suggestion to be made. thx
Check out DC Productions! Great Video Trailers and a DVD is coming soon!!
http://dcproductions.moonfruit.com
Team Reckless Drivers
http://www.driverspaintball.com
foxygrandpa215
PostPosted: Wed Apr 14, 2004 11:30 am    Post subject:
arnt bushmasters low pressure markers?
bagkek
PostPosted: Wed Apr 14, 2004 12:36 pm    Post subject:
Yeah but it should come with a HPR (Regulator) is your current regulator not working? In my opinion you dont Need to have a LP tank, but Regardless of what tank you have you will need a Regulator. I think 450psi is too much for the LPR to handle. The HPR reg will regulate the Psi to around 200ish depending on your over all upgrades. Some people have been ablke to get their regs set around 180 using aftermarket LPRs, Valves, and such.
If you need to replace your Reg then I suggest going with a CP, Sidewinder, or a Gladiator. I personaly just bought a new CP but I havent had a chance to check it out yet, but alot of people here use them and love them.
foxygrandpa215
PostPosted: Wed Apr 14, 2004 4:33 pm    Post subject:
what if i just stick with the stock reg? or should i get a new one?
bagkek
PostPosted: Thu Apr 15, 2004 5:14 am    Post subject:
You can stick with the stock reg for now and it will work just fine. Eventualy you will wont to replace it, but there is now hurry. I have a BKO and a B2k3 and I kept the stock regs on those for the longest time.
The only reason the BKO has an aftermarket reg is because I made a trade to get the b2k3 and the reg was not included in the deal.
Is this gun brand new or used? if it has some use through it then you might want to Clean and relube the Reg but other then that it should work fine.
Now if you start experiencing a bad drop down with your balls, changing out the reg will greatly help with that.
Smile Good luck!!
