Visitors: 96
Total: 96
28: Your Account
77: Your Account
78: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › chaos 2k6 :: Archived
chaos 2k6
cvgwalms
PostPosted: Thu Jun 29, 2006 11:24 am    Post subject: chaos 2k6
so my friend bought it and when i put it in it seems like it send power to the solenoid because it leaks when i turn the power on. then it wont fire. the led blinks but the solenoid doesnt fire. i put the stock board in and it works fine. i tried a buch of different settings and nothing seems to work.
help me Goldie!!!!
p.s. yes the eyes are bypassed.
Goldie
PostPosted: Thu Jun 29, 2006 12:01 pm    Post subject: Re: chaos 2k6
First thing to do would be to reflash the firmware.
cvgwalms
PostPosted: Thu Jun 29, 2006 6:24 pm    Post subject: Re: chaos 2k6
well i tried that and now the board wont turn on.
Spicewon
PostPosted: Fri Jun 30, 2006 2:41 am    Post subject: Re: chaos 2k6
I had an issue with this also the first time I plugged the board in, had to program the board to a preset mode using the trigger programming before it would accept the flash. weird. Now that the board wont turn on, did you check to make sure you have it plugged into the harness corrrectly? Dumb question i know but it is the little things that get forgotten about usually.
Bonebrake M-Series Bushy, Grey/Black Acid wash, Chaos 2K6 Board, Red Valve, Check it Unimount, Stunna harness, Ram mod, Trigger mod, Bonebrake bolt, CP hp reg, Macdev Sonic LPR, Clamping feedneck
cvgwalms
PostPosted: Sun Jul 02, 2006 3:05 pm    Post subject: Re: chaos 2k6
it was on then i flashed it then the led went off and cant get the board back on now. so it was plugged in right.
Goldie
PostPosted: Sun Jul 02, 2006 7:28 pm    Post subject: Re: chaos 2k6
You may have gotten an improper flash.
Make sure it's plugged in and powered on and flash it again and see what happens. That's always the first thing I try when we have problems with boards.
If that doesn't work, feel free to send it in and I can check it out. Did you get my PM?
cvgwalms
PostPosted: Wed Jul 05, 2006 6:05 pm    Post subject: Re: chaos 2k6
yes i got both your pms and ill be sending it to you hopefully this week!
Thanks for all your help!
