Latest: nsgm23ip
Overall: 7935
Visitors: 341
Total: 341
35: Private Messages
99: Home
108: Your Account
116: Home
130: Home
133: Home
142: Home
143: Home
159: Photo Gallery
163: Photo Gallery
165: Photo Gallery
174: Photo Gallery
176: Photo Gallery
184: Photo Gallery
186: Photo Gallery
187: Photo Gallery
188: Home
191: Photo Gallery
195: Photo Gallery
199: Photo Gallery
201: Photo Gallery
205: Photo Gallery
206: Photo Gallery
207: Photo Gallery
211: Photo Gallery
213: Photo Gallery
215: Photo Gallery
216: Photo Gallery
222: Photo Gallery
224: Photo Gallery
225: Photo Gallery
232: Photo Gallery
234: Photo Gallery
235: Photo Gallery
238: Photo Gallery
245: Home
246: Photo Gallery
249: Photo Gallery
250: Home
255: Photo Gallery
258: Home
259: Photo Gallery
261: Photo Gallery
262: Photo Gallery
263: Photo Gallery
266: Photo Gallery
267: Forums
269: Photo Gallery
271: Photo Gallery
272: Forums
273: Forums
274: Forums
275: Forums
276: Photo Gallery
277: Forums
279: Forums
280: Photo Gallery
281: Forums
283: Photo Gallery
284: Photo Gallery
285: Photo Gallery
286: Forums
287: Forums
288: Forums
289: Home
290: Home
291: Photo Gallery
292: Forums
293: Photo Gallery
294: Forums
295: Forums
296: Photo Gallery
297: Forums
298: Forums
299: Photo Gallery
300: Forums
301: Photo Gallery
302: Forums
303: Forums
304: Photo Gallery
305: Forums
306: Forums
307: Forums
308: Forums
309: Photo Gallery
310: Forums
311: Forums
312: Forums
313: Photo Gallery
314: Forums
315: Forums
316: Forums
317: Home
318: Forums
319: Forums
320: Photo Gallery
321: Forums
322: Photo Gallery
323: Forums
324: Photo Gallery
325: Photo Gallery
326: Photo Gallery
327: Forums
328: Photo Gallery
329: Forums
330: Forums
331: Photo Gallery
332: Photo Gallery
333: Forums
334: Forums
335: Forums
336: Forums
337: Forums
338: Forums
339: Home
340: Photo Gallery
341: Forums
Forums › Marker Talk › Problem/Tech forum :: Archives › Check your Eyes? (PDS) :: Archived
PostPosted: Mon Jun 01, 2009 3:23 pm    Post subject: Check your Eyes? (PDS)
Ok, so my project is this Eclipse Bushy with LCD and PDS. I have almost all issues worked out to get this gun up and running except one. I have swapped the LCD wiring harness from my X-mill over to the Eclipse so I could have LCD and PDS. I have the wiring for the Eyes with the connector for the daughter board hooked up. With the harness out of the gun everything works fine(LCD display works, noid fires, etc.) but I have no way to tell if the eyes are working. Regardless of the Eyes switch being on or off the noid still fires. Should not the noid fire if the eyes are switched on and they are "seeing" one another. I realize it should fire if the eyes are not "seeing" each other right? What do you guys think? Bad eyes? Am I just stupid....whats up?
dblk22vball
PostPosted: Mon Jun 01, 2009 4:49 pm    Post subject: Re: Check your Eyes? (PDS)
take the marker into a dark room, and look at the IR transmitter to see if it is lit up with a digital camera, you can even use the one that is on most phones.
You should be able to see a bright dot, or try tripping the trigger and see if it flashes.
If it is solid, then I think you have your transmitter and receiver mixed up, which means that it should flash when you pull the trigger.
This will at least tell you if your eyes are getting power.
ICDO Feedback
PostPosted: Mon Jun 08, 2009 5:59 pm    Post subject: Re: Check your Eyes? (PDS)
ok, tried the dark room/camera test...no results.
I am using a stock LCD bushy board with daughter board lcd/pds connections. My PDS harness connects to the daughter board.
Gun is currently set on "Zip mode" don't know if that makes a difference.
Eyes installed are the older 5mm eyes.
I have a set of 3mm eyes I can install in place of the 5mm ones. Just need to know wich wire is the ground on the 3mm eyes. blue wire or yellow wire? (Standard bushy wire colors)
PostPosted: Mon Jun 08, 2009 11:52 pm    Post subject: Re: Check your Eyes? (PDS)
can you use a digital multi meter to test the emitter and reciever eyes? I want to make sure i havnt damaged them.
Up to this point I have yet to get the eyes to work. If I install the emitter eye in what appears to backwards negative to anode and positive to cathode the noid ceases to fire and the LCD registers "AMMO"...... I'm just so confused.
PostPosted: Tue Jun 09, 2009 9:19 am    Post subject: Re: Check your Eyes? (PDS)
Yes you can use a multimeter to test if they are operating correctly. Essentially when the receiver can see the emitter it closes the circuit so you can test by connecting the leads of your multimeter to your reciever and then blocking and unblocking the emitter.
PostPosted: Tue Jun 09, 2009 1:04 pm    Post subject: Re: Check your Eyes? (PDS)
how about testing the emitter? I tried the camera trick but get nothing emitted from the eye.
Also when replacing the eyes, if you have the anode and cathode reversed will it damge the eye? Or simply just not work?
And I notice the 5mm Fairchild Tx/Rx(that come stock from ICD) are 940nm in wavelength could I go with a 935 or 880 wavelength set as long as they were matched with the same emmission/reception angles being narrow and not wide?
I'm sure it could cause a problem if the angles were too wide...the IR light might go around the ball and never detect it blocking the path.
PostPosted: Tue Jun 09, 2009 4:27 pm    Post subject: Re: Check your Eyes? (PDS)
wow...this eye bizness is really baking my noodle!
on one side of the eye harness i get a constant 1v reading
on the other side(switch side) i get a constant .01v (+/-.002v) that jumps to aprox .05v (+/-.003v)when the trigger is pulled.
Wich side is the emitter and wich is the reciever?
PostPosted: Tue Jun 09, 2009 5:11 pm    Post subject: Re: Check your Eyes? (PDS)
If you reverse the polarity you will fry the component. Typically in older markers the emitter is a dark colour (purple, black-ish) and the receiver is a light colour (white, light blue etc...) when looking directly into the emitter/receiver.
The reason for this is that the black helps to focus the light by reflecting it, and the lighter colour is a filter to reflect light waves that would normally interfere with emitter detection.
Question... is there a little blue or red adjuster knob on your board? Does it look like you can turn it (careful)? I think they were potentiometers for the eye sensitivity on the older boards. Can anyone else confirm this?
PostPosted: Tue Jun 09, 2009 5:21 pm    Post subject: Re: Check your Eyes? (PDS)
yes mine has the blue potentiometer on the board? should it be adjusted?
PostPosted: Tue Jun 09, 2009 5:24 pm    Post subject: Re: Check your Eyes? (PDS)
After fiddling with the potentiometer you spoke of I find it only adjusts the contrast of the LCD display, turning it clockwise has the effect of dimming the LCD until it is blank and vice versa. no luck with it helping the eye problem.
When I look at my ICD eye diagram (WH9306 dated 4/02) it lists the emitter as PN# 1N6264 "Fairchild ifared Emitting diode"
Going to Fairchild Semicondutor's website reveals this is the metal cased diode with the glass lense(just like the diagram shows)
Also PN# QSD723 "Fairchild Photo Detector" Is not listed with Fairchild anymore however it is shown on the diagram with the same profile as the Black plastic one I have.
nike air foamposite
Last post by Angftr12 in Calendar of Events on Mar 20, 2021 at 10:50:17
adidas superstar pas cher
Last post by Angftr12 in Off Topic on Mar 20, 2021 at 10:43:48
