Visitors: 257
Total: 257
78: Home
116: Home
125: Home
126: Home
127: Your Account
136: Home
156: Photo Gallery
157: Photo Gallery
159: Photo Gallery
160: Photo Gallery
163: Photo Gallery
165: Photo Gallery
167: Photo Gallery
173: Photo Gallery
174: Photo Gallery
176: Photo Gallery
177: Photo Gallery
182: Photo Gallery
186: Photo Gallery
187: Photo Gallery
189: Photo Gallery
190: Photo Gallery
191: Photo Gallery
192: Photo Gallery
193: Photo Gallery
198: Photo Gallery
201: Home
203: Photo Gallery
204: Photo Gallery
205: Photo Gallery
206: Photo Gallery
207: Photo Gallery
208: Photo Gallery
209: Photo Gallery
211: Photo Gallery
212: Photo Gallery
213: Photo Gallery
214: Photo Gallery
215: Photo Gallery
217: Photo Gallery
219: Photo Gallery
220: Photo Gallery
221: Photo Gallery
222: Photo Gallery
223: Photo Gallery
224: Photo Gallery
225: Photo Gallery
226: Photo Gallery
228: Photo Gallery
229: Photo Gallery
230: Photo Gallery
231: Home
232: Photo Gallery
235: Photo Gallery
237: Photo Gallery
239: Photo Gallery
240: Photo Gallery
241: Photo Gallery
242: Photo Gallery
243: Photo Gallery
244: Photo Gallery
246: Photo Gallery
247: Home
249: Photo Gallery
250: Photo Gallery
251: Photo Gallery
254: Photo Gallery
256: Photo Gallery
257: Home
Forums › General › Off Topic › My Other Vice...
My Other Vice...
Go to page Previous  1, 2, 3 ... 7, 8, 9 ... 15, 16, 17  Next
PostPosted: Thu Jan 06, 2011 1:37 am    Post subject: Re: My Other Vice...
God, now i know hoe people feel when i talk about autococker timing in front of them
PostPosted: Thu Jan 06, 2011 2:15 am    Post subject: Re: My Other Vice...
That looks clean.
PostPosted: Fri Jan 14, 2011 12:32 pm    Post subject: Re: My Other Vice...
Ok, so I have been out tinkering on this thing every night for the last month. I have put finishing the brakes on hold while I sort out the electrical. The starter relay was giving me fits but thanks to mojocoggo, slowmo and 7t5-27 and I'm sure a couple others at 1stgencelica.com it is now functioning. Here are some pics of progress so far.
I sanded, primed, sanded, primed,sanded some more and repainted the bumper filler panels, a nice result if I do say so myself. Smile
An over view of the driver side engine bay. Kind of a mess with all the wire tracking I had to do. It's pretty ghetto-fied right now with the jumper clips and randome wire running around to test things. Now the starter relay is working off the key I can set off fixing the tail light/dash llight circuit, then I can button the electrical back up and make it pretty again.
Had to bust open the harness to trace wires. The starter relay problem I was having was due to the fact there was no start wire coming off the ignition into the bay. once I got under the dash I saw the start wire with a new wire spliced into it. you can see the splice in he under dash pic. once I found this, I was home free.
Blue wire running over the cowl and into the cockpit to the spliced ignition wire. I put more of the mech looming on the brake reservoir hoses to jazz them up a bit.
Here is the blue splice connector...some shade tree mechanic'n went on at some point before I owned it.
Here is the driver side engine bay, need to figure out what that connector goes to there in the middle of the pic....but that's another thread.
MuthaFunk
PostPosted: Fri Jan 14, 2011 3:18 pm    Post subject: Re: My Other Vice...
What a wild ride!! An excellent thread! I can't wait to follow this through until your done!! Subscribed!
Always looking for better.....
PostPosted: Mon Jan 17, 2011 1:16 pm    Post subject: Re: My Other Vice...
I had always noticed that the driver's seat had a slight lean toward the driver door. I thought it was just a bent seat frame. Once I pulled the seat and carpet when laying the new battery cable I saw the real problem. The rear seat perch coming off the frame rail was cracked! Crap.... I happened to mention it to one of my sunday school students sunday morning and he told me how he had a Mig setup and had been welding since he was 10, he's 17 now. so he brought over his rig and went to work. Nice job and best of all ...FREE! Smile
Here's my man Hunter stitching up the crack
Welded up
I hit the weld with some black paint to seal it up. The metal around the bracket got real thin and even on the lowest setting the welder still wanted to burn through but he was able to carefully fix it. Still looks good and is probably stronger than when the car was built. I jumped on the perch a few times and it didn't budge.
also, I hooked up and installed the starter motor. I hit the key and for the first time in almost 8 years the engine turned over! Still havn't hooked up fuel and spark so I wasn't looking for it to fire but at least the engine turns and the start system is functioning properly. exciting!
PostPosted: Mon Jan 17, 2011 2:55 pm    Post subject: Re: My Other Vice...
Geez, that looks really awesome Crash. In case I haven't made this joke yet, make sure you don't forget to put a johnson rod in there.
PostPosted: Mon Jan 17, 2011 10:06 pm    Post subject: Re: My Other Vice...
while at work i printed out a wiring diagram i found here on the net and traced the tail light/dash light circuit with a hilighter. that was very revealing. once i knew what i was looking for the problem was pretty obvious. i tracked down a splice in the circuit that was very old and corroded and beginning to burn. once i cut that out and connected it with a jumper wire everything lit up just like it was supposed to. so now my electrical issues are solved at the moment. i'm sure things will pop back up once i move on to the ignition. Smile
PostPosted: Tue Jan 18, 2011 12:57 am    Post subject: Re: My Other Vice...
Looking good, Crash. Can we haz turboz now?
PostPosted: Tue Jan 18, 2011 1:38 am    Post subject: Re: My Other Vice...
Noe turbos. Haz tween kamz
PostPosted: Tue Jan 18, 2011 1:43 am    Post subject: Re: My Other Vice...
Awesome stuff.
How much longer do you think before you can take it for a spin?
Page 8 of 17
