Latest: Osweiler
Overall: 7925
Visitors: 415
Total: 415
03: Your Account
95: Home
165: Photo Gallery
177: Home
182: Photo Gallery
186: Photo Gallery
198: Photo Gallery
204: Photo Gallery
207: Photo Gallery
210: Photo Gallery
215: Photo Gallery
218: Photo Gallery
223: Photo Gallery
240: Photo Gallery
248: Photo Gallery
249: Photo Gallery
251: Photo Gallery
257: Photo Gallery
258: Photo Gallery
259: Photo Gallery
262: Forums
263: Forums
265: Forums
267: Photo Gallery
271: Photo Gallery
272: Forums
273: Photo Gallery
274: Forums
275: Forums
277: Forums
279: Forums
280: Photo Gallery
281: Forums
282: Photo Gallery
283: Forums
284: Photo Gallery
285: Forums
286: Photo Gallery
287: Forums
288: Forums
289: Forums
290: Forums
291: Forums
292: Forums
293: Forums
294: Photo Gallery
295: Forums
296: Photo Gallery
297: Forums
298: Photo Gallery
299: Forums
300: Forums
301: Forums
302: Forums
303: Photo Gallery
304: Photo Gallery
305: Forums
306: Forums
307: Forums
308: Forums
309: Home
310: Forums
311: Forums
312: Forums
313: Forums
314: Forums
315: Forums
316: Forums
317: Forums
318: Photo Gallery
319: Forums
320: Forums
321: Photo Gallery
322: Forums
323: Home
324: Photo Gallery
325: Forums
326: Forums
327: Forums
328: Forums
329: Forums
330: Forums
331: Forums
332: Photo Gallery
333: Photo Gallery
334: Forums
335: Forums
336: Photo Gallery
337: Photo Gallery
338: Forums
339: Forums
340: Forums
341: Forums
342: Forums
343: Forums
344: Forums
345: Forums
346: Forums
347: Photo Gallery
348: Forums
349: Forums
350: Forums
351: Forums
352: Forums
353: Forums
354: Forums
355: Forums
356: Forums
357: Forums
358: Photo Gallery
359: Forums
360: Forums
361: Photo Gallery
362: Forums
363: Forums
364: Forums
365: Forums
366: Forums
367: Forums
368: Forums
369: Forums
370: Forums
371: Home
372: Forums
373: Forums
374: Forums
375: Forums
376: Forums
377: Photo Gallery
378: Forums
379: Forums
380: Forums
381: Photo Gallery
382: Photo Gallery
383: Forums
384: Forums
385: Forums
386: Forums
387: Forums
388: Photo Gallery
389: Forums
390: Forums
391: Forums
392: Forums
393: Photo Gallery
394: Forums
395: Photo Gallery
396: Photo Gallery
397: Forums
398: Forums
399: Forums
400: Forums
401: Forums
402: Forums
403: Forums
404: Forums
405: Home
406: Forums
407: Photo Gallery
408: Photo Gallery
409: Photo Gallery
410: Forums
411: Photo Gallery
412: Photo Gallery
413: Forums
414: Forums
415: Forums
My Other Vice...
Go to page Previous  1, 2, 3 ... 9, 10, 11 ... 15, 16, 17  Next
PostPosted: Mon Mar 07, 2011 9:09 pm    Post subject: Re: My Other Vice...
slowly but surely you're putting this together.
PostPosted: Tue Mar 08, 2011 12:27 pm    Post subject: Re: My Other Vice...
Refinished the grill and trim.
Refinished the C-pillar vents.
Engine bay as it currently sits, intalled new plug wires, not much but they are nice and fresh.
PostPosted: Tue Mar 08, 2011 1:00 pm    Post subject: Re: My Other Vice...
so how long till you can start it? what else is on the list to finish the car?
PostPosted: Tue Mar 08, 2011 1:58 pm    Post subject: Re: My Other Vice...
1.Need to finish laying the new carpet so i can-
2.put the gas pedal and heater core box back in. Then-
3. I can hook up the heater hoses and seal up the cooling system and-
4. fill it with coolant.
5.shorten throttle linkage rod and rethread the shortened end to connect the gas pedal to the carbs.
6. install the MSD box
7. put the key in and start!
That's just to make it go VROOM....
Still need to get new front turn signals and adress the reverse light wiring. My stainless steel brake line set should show up next week, then i can install it all and re-bleed the braking system, so once it goes vroom I can stop it.
After all that it's time for paint and peassemby, install the glass etc. etc.
hoping to have this all done by september for the JCCS car show at the Queen Mary in long beach CA.
PostPosted: Tue Mar 08, 2011 10:11 pm    Post subject: Re: My Other Vice...
Managed to fit the Headers up. Flange was drilled for 8mm studs, had to open those up to accomodate the 10mm studs my 253 head has. No metric drill bits around the shop so a 7/16 did the trick albeit a little oversized.
Even after opening up the stud holes it still didn't want to slide on. the heater hose provision on the back of the head is right next to/behine the 4 port....really tight. made a little niche in the flange to fix that prob.
What?! You don't like my green paint? I think it sets off the blue quite nicely... Rolling Eyes
Don't worry most of the paint is on my hands now.
PostPosted: Thu Mar 10, 2011 11:44 am    Post subject: Re: My Other Vice...
Went to my Local ACe Hardware and picked up some 1/2-20 steel allen head plugs and a 1/2-20 Tap and threaded the EGR ports below ports 2,3 and 4. when I got the engine the ports were just plugged by jamming an M12 bolt in them but those wouldn't clear the header flange, plus they looked a little ghetto. I wanted the ports plugged more professionally and wanted them to be easily removed or reinstalled if ever the need arose. The result was a nice plug that sits flush and is removeable with a 1/4" alen key.
PostPosted: Thu Mar 10, 2011 12:12 pm    Post subject: Re: My Other Vice...
there you go, using paintball knowledge and tools on a car. how dare you.
looks good. its always the little things that make all the difference.
PostPosted: Thu Mar 10, 2011 12:48 pm    Post subject: Re: My Other Vice...
Well, actually it's the other way around. Smile
PostPosted: Fri Mar 11, 2011 12:37 pm    Post subject: Re: My Other Vice...
I definitely try to pay attention to the little things... I must have at least some level of determination as this project is pushing the 9 year mark. Smile
Iwent out to the garage for an hour or so to finish the carpet on the driver's side so i could reinstall the gas pedal. Now that the gas pedal is back in I can finish the throttle linkage. sorry for the poor quality phone pic, and the little bit of debris on the carpet.
Rudz
PostPosted: Fri Mar 11, 2011 9:41 pm    Post subject: Re: My Other Vice...
getting there
looks good mang
ADDIX Paintball
Action Star Games
Almost Famous Photography
BIGEVILONLINE.COM
Page 10 of 17
Mike Tomlin implies there is a trong possibilitythe Steelers
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:45:00
Packers stay on offense, add RB A.J. Dillon
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:39
For 2nd straight season, Seahawks offense struggling to fly
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:44:12
Chiefs welcome fresh/outdated faces inside of Allen
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:58
Run defense issues highlight total breakdown for Saints
Last post by Osweiler in Calendar of Events on Nov 26, 2020 at 03:43:15
Pitch and catch: Round 2 of NFL draft heavy on receivers
Last post by Osweiler in Off Topic on Nov 26, 2020 at 03:42:37
Corridor of Fame QB Jim Kelly suggests checks demonstrate re
Last post by Osweiler in Paintball talk on Nov 26, 2020 at 03:42:15
How do you hit pictures in NBA2K21?
Last post by wfuuopy in Off Topic on Nov 20, 2020 at 01:53:02
RuneScape is Free-To-Play
Last post by wfuuopy in Paintball talk on Nov 20, 2020 at 01:52:09
If You Are Clever About It
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:05:37
