Latest: NisaDisco
New Yesterday: 1
Overall: 7919
Visitors: 107
Total: 107
20: Your Account
22: Home
27: Your Account
101: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Help with BKO leak from body/grip area :: Archived
Go to page Previous  1, 2, 3  Next
BKO2013
PostPosted: Tue Mar 22, 2011 9:50 pm    Post subject: Re: Help with BKO leak from body/grip area
Thanks for all the help. I am using compressed air. Its set for low pressure.
BKO2013
PostPosted: Fri Apr 01, 2011 5:05 pm    Post subject: Re: Help with BKO leak from body/grip area
Sooo i borrowed my cousins 04 BKo. It was shooting ok and since it didnt have an on/off asa and the tank was near empty i dry fired to empty the tank. Then it started leaking like crazy from inside the gun just like mine was! I couldn't believe it! What should I do?
PostPosted: Fri Apr 01, 2011 5:22 pm    Post subject: Re: Help with BKO leak from body/grip area
it could be that there isn't enough pressure to fully push the bolt back, so its causing the leak. put air to the gun, and push back the bolt, to seat it. if it stops leaking, then its just a pressure issue. if it doesn't then there is a oring that is nicked or frayed.
BKO2013
PostPosted: Fri Apr 01, 2011 5:28 pm    Post subject: Re: Help with BKO leak from body/grip area
the bolt is all the way back so it must be an oring. My gun never came with a proper allen key to get the screws on the underside of thhe gun.
dsmr5456
PostPosted: Sat Apr 02, 2011 2:59 pm    Post subject: Re: Help with BKO leak from body/grip area
Have you checked the poppet valve? Your problem sounds identical to a problem I had a few months back.
You need to take the body off of the tray and frame, and there is a screw about halfway between the part that the reg screws into and the ram, it holds the valve in. You can then remove all of the pieces along w/ the LPR.
If your cupseal on the poppet looks like this, or the seal has some scratches on it, you need to replace it
BKO2013
PostPosted: Sat Apr 02, 2011 10:41 pm    Post subject: Re: Help with BKO leak from body/grip area
Ok thanks that was very helpful! Where can i find replacemnt parts for the BKO though?
PostPosted: Sat Apr 02, 2011 10:52 pm    Post subject: Re: Help with BKO leak from body/grip area
Ask around, im sure Justa 181 can help you out.
PostPosted: Sun Apr 03, 2011 12:20 am    Post subject: Re: Help with BKO leak from body/grip area
unscrew the brass cap, and flip the seal. you should be able to use it still.
BKO2013
PostPosted: Sun Apr 03, 2011 2:45 pm    Post subject: Re: Help with BKO leak from body/grip area
to access those parts do i need to take out the four screws in the underside corners of the gun? Sorry if i sound like an idiot. Two of the screws are stripped and i cant get them out.
dsmr5456
PostPosted: Sun Apr 03, 2011 8:40 pm    Post subject: Re: Help with BKO leak from body/grip area
Ya, those four screws, and preferably the two larger ones that hold the peice that the reg screws into. Getting that part off helps clear things up.
As far as being stripped...I dont have my gun on me, and don't remember how deep those screws are. I will get back to you when I get home to grab my bko because I know a couple methods to get get stripped socket caps out.
Page 2 of 3
Nike Air Max 90 zu seiner
Last post by NisaDisco in Bushmaster General talk on Aug 08, 2020 at 07:47:37
asics scarpe basso prezzo
Last post by NisaDisco in PRP General Forum on Aug 08, 2020 at 07:43:09
basket adidas femme pas cher
Last post by NisaDisco in PRP General Forum on Aug 08, 2020 at 07:38:37
nike air max 2090 hombre
Last post by NisaDisco in Bushmaster General talk on Aug 08, 2020 at 07:34:03
