Latest: wfuuopy
Overall: 7924
Visitors: 444
Total: 444
55: Your Account
107: Home
156: Photo Gallery
163: Photo Gallery
181: Photo Gallery
187: Photo Gallery
198: Home
201: Photo Gallery
203: Photo Gallery
205: Photo Gallery
206: Photo Gallery
207: Photo Gallery
216: Photo Gallery
227: Photo Gallery
237: Photo Gallery
238: Home
247: Photo Gallery
248: Photo Gallery
254: Photo Gallery
257: Photo Gallery
262: Forums
263: Forums
265: Forums
267: Forums
271: Forums
272: Forums
273: Forums
274: Photo Gallery
275: Forums
277: Forums
278: Photo Gallery
279: Forums
280: Forums
281: Photo Gallery
283: Photo Gallery
285: Forums
286: Forums
287: Forums
288: Forums
289: Forums
290: Photo Gallery
291: Forums
292: Forums
293: Forums
294: Forums
295: Forums
296: Forums
297: Forums
298: Forums
299: Forums
300: Forums
301: Forums
302: Forums
303: Forums
304: Forums
305: Forums
306: Forums
307: Forums
308: Forums
309: Forums
310: Forums
311: Forums
312: Forums
313: Forums
314: Forums
315: Forums
316: Forums
317: Forums
318: Forums
319: Forums
320: Forums
321: Photo Gallery
322: Forums
323: Forums
324: Photo Gallery
325: Forums
326: Forums
327: Forums
328: Forums
329: Forums
330: Forums
331: Forums
332: Forums
333: Forums
334: Forums
335: Photo Gallery
336: Forums
337: Forums
338: Forums
339: Forums
340: Forums
341: Forums
342: Forums
343: Forums
344: Forums
345: Forums
346: Forums
347: Forums
348: Photo Gallery
349: Photo Gallery
350: Forums
351: Photo Gallery
352: Forums
353: Forums
354: Forums
355: Forums
356: Forums
357: Forums
358: Forums
359: Forums
360: Forums
361: Photo Gallery
362: Forums
363: Forums
364: Forums
365: Forums
366: Forums
367: Forums
368: Forums
369: Forums
370: Photo Gallery
371: Forums
372: Photo Gallery
373: Forums
374: Forums
375: Forums
376: Photo Gallery
377: Forums
378: Forums
379: Forums
380: Photo Gallery
381: Forums
382: Forums
383: Forums
384: Forums
385: Photo Gallery
386: Forums
387: Forums
388: Forums
389: Forums
390: Forums
391: Forums
392: Forums
393: Forums
394: Forums
395: Forums
396: Photo Gallery
397: Forums
398: Forums
399: Forums
400: Forums
401: Forums
402: Forums
403: Forums
404: Forums
405: Forums
406: Forums
407: Forums
408: Photo Gallery
409: Photo Gallery
410: Forums
411: Forums
412: Forums
413: Photo Gallery
414: Forums
415: Forums
416: Forums
417: Forums
418: Forums
419: Forums
420: Forums
421: Forums
422: Photo Gallery
423: Forums
424: Forums
425: Forums
426: Forums
427: Photo Gallery
428: Home
429: Forums
430: Forums
431: Forums
432: Photo Gallery
433: Forums
434: Forums
435: Forums
436: Forums
437: Forums
438: Forums
439: Forums
440: Forums
441: Forums
442: Forums
443: Forums
444: Forums
Forums › Marker Talk › Problem/Tech forum :: Archives › Just snapped the MI solonoid wire... on good friday... :: Archived
PostPosted: Mon Apr 04, 2011 5:33 pm    Post subject: Just snapped the MI solonoid wire... on good friday...
Just noticed this, the bolt sticks out farther than it should and blocks the ball from feeding, will this correct it self when aired up?
PostPosted: Mon Apr 04, 2011 6:22 pm    Post subject: Re: MI Bko bolt feeding problem.
Well the bolts on the ICD stuff are not adjustable so it should clear the breach. Remember, there is no air forcing the ram/bolt into the open position it is the ram spring. So no, airing up the gun will have no affect on the bolt's open position.
Check to make sure that the bolt pin is actually in the hammer slot and not infront of the hammer.
It is possible (not likely) that the hammer has come unscrewed from the ram shaft. Pretty easy to check this (just take the ram out of the gun).
Finally make sure someone didn't put in some piece of something under the ram cap to keep the bolt from going all the way back. Just remove the ram cap. I actually had to do just this, I installed a small piece of macro to make the bolt sit a bit farther forward as the eyes I milled in the breach were a tad low....but that is really a discussion for another time.
So, just try the above things and see what happens.
PostPosted: Mon Apr 04, 2011 6:29 pm    Post subject: Re: MI Bko bolt feeding problem.
when not aired up the bolt sits all the way open not blocking the breach, when you look down the feedneck the bolt should clear the breach, if not then your pin is probably not seating into the ram and is in front of it.
PostPosted: Tue Apr 05, 2011 12:01 am    Post subject: Re: MI Bko bolt feeding problem.
Fivestring, I think he's got the old square end ram, so he can't pull the cap. Check your pin placement and see if the hammer is unscrewed, as suggested.
PostPosted: Tue Apr 05, 2011 12:35 am    Post subject: Re: MI Bko bolt feeding problem.
screw is locked, pin is lined...
PostPosted: Tue Apr 05, 2011 1:05 am    Post subject: Re: MI Bko bolt feeding problem.
pics would help
PostPosted: Fri Apr 22, 2011 10:08 pm    Post subject: Re: Just snapped the MI solonoid wire... on good friday...
it works with electrical tape but it slides out...
PostPosted: Tue May 17, 2011 7:09 pm    Post subject: Re: Just snapped the MI solonoid wire... on good friday...
Uh, how long does the wire need to be striped for the solder to bond the two wires back together? i have 1/4 an inch both sides.
PostPosted: Tue May 17, 2011 7:24 pm    Post subject: Re: Just snapped the MI solonoid wire... on good friday...
It has to be 3/4 of the O.D of the wire to the 10th power, then subtract the total length of the wire. After you do that, take the I.D of the wire and multiply that by the bonding strength of the tin. Then you will have the length needed... comprende?
How do you hit pictures in NBA2K21?
Last post by wfuuopy in Off Topic on Nov 20, 2020 at 01:53:02
RuneScape is Free-To-Play
Last post by wfuuopy in Paintball talk on Nov 20, 2020 at 01:52:09
If You Are Clever About It
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:05:37
Their Previous Narrative Manners
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:04:15
You'Ll Take A Massive Loss On The Maples
Last post by Kingang in Off Topic on Nov 18, 2020 at 10:02:01
Last post by Tzarector in ICD Gear Forum on Nov 05, 2020 at 17:20:50
adidas online kopen
Last post by YAz45mmi in Calendar of Events on Oct 24, 2020 at 04:06:09
NikeLab Dunk Lux SP Dark
Last post by YAz45mmi in Off Topic on Oct 24, 2020 at 03:59:37
Converse har spillet med
Last post by YAz45mmi in Paintball talk on Oct 24, 2020 at 03:51:39
adidas EQT-Kissen ADV
Last post by YAz45mmi in PRP General Forum on Oct 24, 2020 at 03:45:37
