Visitors: 88
Total: 88
Forums › Marker Talk › Problem/Tech forum :: Archives › detent problems :: Archived
detent problems
urbansix
PostPosted: Sun Mar 07, 2004 10:01 am    Post subject: detent problems
I kept double feeding, so i noticed the detent was stuck upen, probably from chopping, and gooing it up with paint. I took it apart, cleaned is, put a little Gold Cup on it, but it still sticks open alot. It's a stainless steel ball.
Tantrum has a Macdev teflon ball detent, but it says that its for pre-2003 bushies. I have a 2003 electronics, with 2002 xmilling (pic here) - how do I know which will fit? If the newer ones have o-ring detents then the macdev teflon should fit mine right??
I really need to get this fixed since I'm getting a force feed hopper soon...
...have you ever retired a human by mistake?
View user's profile Yahoo Messenger
JRio
PostPosted: Sun Mar 07, 2004 11:13 am    Post subject:
the macdev one will work fine since you already have a ball detent on your gun
sounds like it just has a bunch of goo stuck in there, happen with my bko ones i just let it run under a foucet and it got all the goo out and was fine
"Time is a waste of life, life is a waste of time, so get wasted all the time and have the time of your life"
Nator187
PostPosted: Sun Mar 07, 2004 9:52 pm    Post subject:
You can try to clean them for a quick fix. But your better off getting a new one.
Nator187
www.shootpaint.com www.RedzComfort.com www.Icdpaintball.com www.NitroDuck.com www.BushmasterSource.com
View user's profile Send e-mail Visit poster's website ICQ Number AIM Address
CoBrA2K3
PostPosted: Tue Mar 09, 2004 8:55 pm    Post subject:
drill a hole in the back and put wd40 in it... thats what happened to me, i was feeding like 4balls at a time.. not it wokrs fine and i have a good place to put loob in it.
www.pbnation.com/showt...did=450543
www.canadianpaintball....8088#18088
sniperbob.cjb.net/goodtraders.html
Mailman
PostPosted: Tue Mar 16, 2004 6:34 pm    Post subject:
what do u mean by the ball detent "sticking open"? i didnt know the stainless ball detents moved
WoOlFiN_MaN
PostPosted: Wed Mar 17, 2004 8:12 pm    Post subject:
wait mine is stuck also how did you take your detent apart?
urbansix
PostPosted: Wed Mar 17, 2004 10:20 pm    Post subject:
Woolfin - by taking it apart I meant unscrewing it from the gun and then cleaning it & lubing it.
I went ahead and got the macdev teflon ball. I works much better - be careful when screwing it in that you dont round off the allen hex hole...the aluminum seems thin & soft.
WoOlFiN_MaN
PostPosted: Thu Mar 18, 2004 9:32 am    Post subject:
o ok i was goin to get a new detent when my bushy gets back from vapor anyways
CoBrA2K3
PostPosted: Thu Mar 18, 2004 1:33 pm    Post subject:
drill a hole in the back of the detent and push it out, thats what i did
Last post by Wjb10776 in ICD Gear Forum on May 24, 2019 at 01:15:56
