Latest: bwh08
Overall: 7916
Visitors: 302
Total: 302
87: Home
92: Home
113: Home
118: Home
131: Home
137: Home
156: Photo Gallery
160: Photo Gallery
165: Photo Gallery
168: Photo Gallery
183: Photo Gallery
184: Photo Gallery
188: Home
190: Photo Gallery
195: Home
198: Photo Gallery
199: Photo Gallery
203: Photo Gallery
204: Home
209: Home
210: Photo Gallery
211: Photo Gallery
212: Photo Gallery
215: Photo Gallery
219: Photo Gallery
227: Photo Gallery
228: Home
235: Photo Gallery
236: Home
237: Photo Gallery
238: Photo Gallery
249: Photo Gallery
250: Photo Gallery
253: Your Account
257: Forums
258: Home
260: Photo Gallery
262: Forums
263: Forums
265: Forums
267: Forums
271: Photo Gallery
272: Forums
273: Forums
274: Forums
275: Forums
277: Photo Gallery
279: Forums
280: Forums
281: Photo Gallery
283: Forums
284: Photo Gallery
285: Forums
286: Photo Gallery
287: Photo Gallery
288: Forums
289: Forums
290: Forums
291: Forums
292: Forums
293: Forums
294: Forums
295: Forums
296: Forums
297: Forums
298: Forums
299: Forums
300: Forums
301: Forums
302: Forums
Forums › Marker Talk › Problem/Tech forum :: Archives › Promaster Nox board problem :: Archived
george989
PostPosted: Fri Aug 12, 2011 3:12 pm    Post subject: Promaster Nox board problem
Hey, can anyone tell me how to turn the eyes on and off on a Promaster NOX board. I just recently purchased one from a member on ICDO and I'm having trouble getting the eyes to work. The noid will click whether or not there is anything in the breech. I appreciate any help that I can get! Confused
04 BKO-Stock
05 Promaster-NOX board, ebay valve, CP feedneck, Shocktech asa, Dye ultralite barrel, Delrin bolt pin, Crammer, Bloodline grips
PostPosted: Fri Aug 12, 2011 9:48 pm    Post subject: Re: Promaster Nox board problem
Hrmm. Not sure on the board but is it possible that the eyes are the problem? Have you tested with a normal promaster board?
PostPosted: Fri Aug 12, 2011 10:17 pm    Post subject: Re: Promaster Nox board problem
To turn OFF the eyes on a NOX, you just hold the trigger down, turn on the marker and keep holding it down for another 2 seconds.
Check your harness. Sounds like one of your eye wires could be compromised.
EDIT: Just thought about it. The previous user might have just disabled using the eyes in one of the registers. Download the NOX manual from the file download section and go through all the registers and change what you need to and write down everything else so you know what the board is set to in the future.
PostPosted: Sat Aug 13, 2011 12:56 am    Post subject: Re: Promaster Nox board problem
the registers are for the Kila boards, not the Nox. but the download section does have the Nox board programming, Nox Board.
PostPosted: Sat Aug 13, 2011 2:34 am    Post subject: Re: Promaster Nox board problem
The eyes should be on by default I think.
You should probably inspect the eye wires.
george989
PostPosted: Sat Aug 13, 2011 12:04 pm    Post subject: Re: Promaster Nox board problem
No, I put my original board back in my marker and the eyes work just fine. Also this marker has never really been used, its pratically brand new so all the wires are in perfect condition. The Nox board is however missing one of the pins on board. I was wondering if that could cause the eyes not to work. I will try everyones suggestions. Thanks for the help!!!
04 BKO-Stock
PostPosted: Sat Aug 13, 2011 1:19 pm    Post subject: Re: Promaster Nox board problem
The nox board comes missing a pin.
STEWIEDP13
PostPosted: Sat Aug 13, 2011 1:21 pm    Post subject: Re: Promaster Nox board problem
As far as I know a lot of the pred & nox boards had a pin missing. I have a pred lite in my NDFS7 that has a pin missing and it does not affect nothing at all. as a matter of fact on the harness there are about 3 unused holes that do not do any thing except let the pins rest in.
Here is my feedback page: www.icd-owners.com/htm...ic&t=13198
STEWIEDP13
PostPosted: Sat Aug 13, 2011 1:23 pm    Post subject: Re: Promaster Nox board problem
I have never had a promaster. Is the harness set up the same as the freestyles?
PostPosted: Sat Aug 13, 2011 1:56 pm    Post subject: Re: Promaster Nox board problem
I would think so. I never noticed on the PM that I sold for a friend.
