Latest: Skyzhay
Overall: 7947
Visitors: 406
Total: 406
28: Home
93: Home
94: Home
103: Home
109: Home
110: Home
114: Home
117: Home
119: Home
174: Photo Gallery
183: Photo Gallery
185: Home
196: Home
198: Photo Gallery
202: Home
205: Photo Gallery
238: Photo Gallery
245: Photo Gallery
247: Photo Gallery
248: Photo Gallery
250: Home
256: Photo Gallery
257: Forums
258: Home
261: Photo Gallery
262: Forums
263: Forums
264: Home
265: Forums
267: Forums
271: Home
272: Forums
273: Photo Gallery
274: Forums
275: Forums
276: Photo Gallery
277: Forums
279: Photo Gallery
280: Forums
281: Photo Gallery
283: Forums
285: Forums
286: Forums
287: Forums
288: Forums
289: Forums
290: Photo Gallery
291: Forums
292: Photo Gallery
293: Forums
294: Home
295: Forums
296: Forums
297: Photo Gallery
298: Photo Gallery
299: Forums
300: Forums
301: Home
302: Home
303: Forums
304: Forums
305: Forums
306: Forums
307: Forums
308: Home
309: Forums
310: Forums
311: Forums
312: Forums
313: Photo Gallery
314: Forums
315: Forums
316: Forums
317: Forums
318: Home
319: Forums
320: Photo Gallery
321: Forums
322: Forums
323: Forums
324: Forums
325: Forums
326: Photo Gallery
327: Forums
328: Photo Gallery
329: Forums
330: Forums
331: Forums
332: Photo Gallery
333: Forums
334: Forums
335: Forums
336: Forums
337: Forums
338: Forums
339: Forums
340: Forums
341: Home
342: Forums
343: Photo Gallery
344: Forums
345: Forums
346: Forums
347: Forums
348: Forums
349: Forums
350: Forums
351: Forums
352: Forums
353: Photo Gallery
354: Forums
355: Photo Gallery
356: Forums
357: Forums
358: Forums
359: Forums
360: Forums
361: Home
362: Forums
363: Forums
364: Photo Gallery
365: Forums
366: Photo Gallery
367: Forums
368: Forums
369: Photo Gallery
370: Photo Gallery
371: Forums
372: Forums
373: Forums
374: Forums
375: Forums
376: Forums
377: Forums
378: Home
379: Forums
380: Forums
381: Forums
382: Forums
383: Forums
384: Forums
385: Forums
386: Forums
387: Photo Gallery
388: Forums
389: Photo Gallery
390: Forums
391: Forums
392: Photo Gallery
393: Forums
394: Forums
395: Forums
396: Forums
397: Forums
398: Forums
399: Forums
400: Forums
401: Forums
402: Forums
403: Forums
404: Forums
405: Photo Gallery
406: Photo Gallery
Forums › Marker Talk › Problem/Tech forum :: Archives › damn bushy, more problems!!!!~any help?? :: Archived
bushyguy721
PostPosted: Sun Mar 28, 2004 7:02 pm    Post subject: damn bushy, more problems!!!!~any help??
ok i was gunna sell ym gun today locally......BUT my bushy was leakin and when i shot the led light didnt blink
i dont care about the light cus well who cares, but the damn leak bothers me sooo much and he wouldnt buy it until i fixed it...i leaks somewhere inside around where the noid is i think its that but i dunno...after doin some taken apart i think its either the lpr or the valve
if it is that how do i fix it, buy a new noid?
i need some help please, if i need to take it apart any pics would be apprecaited
misterj0shua
PostPosted: Sun Mar 28, 2004 8:29 pm    Post subject: Some Ideas
I just got through a bunch of crap with the bushy (im also haveing the same problem believe it or not) I have and here are a few ideas that may or may not help ya.
I can tell ya its not the valve. You said it was leaking around the noid. If it was the valve you would have all sorts of leakage around the gun...down the barrell...etc. everything in that noid is regualted internally though little tunnels and holes on the gun. But the noid I noticed through the last several months will bleed (or leak) off in two ways. Either A. The pressure is too high or B. 1 of the o-rings on the noid is bad. you then ask ok how do i know which one. What i do is take apart my gun and gas it up. Where the noid attaches to the frame if the air leakes out of their then it is a oring or the noid is attached tight enough. 2. between the base of the noid and the noid itself...the only thing i can figure is this is where it bleeds off excess pressure.
now if it 2 then you got two problems. Either A. Your LPR is not working correctly (or is too far in) or B. The noid is bad. This is where i am stuck now. The most im going to do is replace the orings on the piston in the LPR and if that dont work...im going to have to buy a new noid.
The question I have is (which im sure is a yes). Does the piston on the lpr move every shot...or does it saty where it is. Cause if that is the problem...that would explain my issues.
oh btw.....the noid needs a certain number of volts to function so you may want to look at a battery issue too. Also check out the wiring harness and may sure there are no disconnections...just a though
Laughing
Barber
Hope this helped...
misterj0shua
PostPosted: Sun Mar 28, 2004 8:52 pm    Post subject: BTW I found this...
I found this while searching for the problem....I guess we are having it should help. This should tell ya whether you need a new noid.
www.icd-owners.com/htm...pic&t=1187
Big_Mac
PostPosted: Mon Mar 29, 2004 9:15 am    Post subject:
Didn't read the referenced post...hope I'm not repeating.
Yes, check the LPR...too high will cause the noid to bleed off. Check the screw holding the noid to the ram to make sure they are tight.
that's all I can think of right now. Smile
Stupidity Kills
misterj0shua
PostPosted: Mon Mar 29, 2004 9:50 pm    Post subject: Fixed problem....
Just an update...i replaced the piston o-rings and adjusted the pressure between the HPR and the LPR and it works great...
bushyguy721
PostPosted: Thu Apr 08, 2004 11:03 am    Post subject:
sry i havnt replied to the thread lately, i am goin to the field today and everyone knows bushys there so we all will fix it, hopefully i wont have to get a new noid, if i do then crap.....THANKS for all you guy's help its been greatly appriecaited
Blocks and steals are pretty good
Last post by Skyzhay in Freestyle General Talk on Sep 07, 2021 at 08:33:50
Madden NFL 22: Tight End Ratings
Last post by Skyzhay in Paintball talk on Sep 07, 2021 at 08:32:38
Really appreciated the group facets of dungoneering
Last post by Skyzhay in Off Topic on Sep 07, 2021 at 08:31:33
Chaussures de Nike KD
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:08:23
Converse All Star Precio
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:05:32
Nike Air Foamposite Shoes
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 04:02:18
Nike Air Max 1 Schoenen
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:58:34
Prodotti Adidas Nizza
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:52:24
Chaussures de Nike Air Vortex
Last post by laywin in ICD Mech Markers on Aug 26, 2021 at 03:47:18
Marlboro Cigarettes Online thirty minutes
Last post by sellcigarette in Paintball talk on Aug 23, 2021 at 09:36:02
