Latest: Johnonsmith
Overall: 7920
Visitors: 270
Total: 270
30: Your Account
54: Home
87: Home
113: Home
114: Home
134: Home
135: Home
141: Home
144: Home
145: Home
153: Statistics
160: Home
166: Home
171: Home
172: Home
174: Photo Gallery
182: Home
184: Home
187: Photo Gallery
190: Photo Gallery
191: Home
192: Home
195: Home
205: Photo Gallery
218: Photo Gallery
219: Photo Gallery
221: Photo Gallery
222: Home
226: Photo Gallery
230: Home
237: Home
245: Home
258: Photo Gallery
259: Photo Gallery
260: Home
262: Forums
263: Forums
264: Home
265: Home
267: Home
Forums › Marker Talk › Problem/Tech forum › Freestyle FS-7 Help
Freestyle FS-7 Help
Go to page 1, 2, 3, 4  Next
JBacon
PostPosted: Wed Jun 06, 2012 1:42 am    Post subject: Freestyle FS-7 Help
Lately I have had nothing but problems with my IDC Freestyle fs7. Currently it does not shoot, and has a small, but noticeable leak inside of the gun. Last august I bought the fs7, and it worked great throughout the rest of the summer, and the school year... up until this season. I brought it out to the field to play, and it worked great all day. The last game I blew the smallest o-ring inside of the bolt and about 2500psi was drained through the gun. This happened based solely on my personal paintball inexperience, and not unscrewing the tank, or at least using the on/off. After this happened I then bought an o-ring kit off eBay, and replaced the broken o-ring. Through the process off my amateur paintball marksmanship, I unbalanced the regulators, and may have caused problems that I am not aware of. The problem right away was that the bolt would not go back, and into the position where the eyes would detect it, and allow me to shoot. Because of this, the air would just go through the gun. Later, to try to fix this I ended up backing the lpr all the way out, and the bolt set its self where it needed to be. At this point two more problems occurred.
1. There was a faint leak from somewhere inside of the gun (enough to notice if the marker was sitting on the table)
2. When I adjusted the lpr to shoot, (the leak still there) when it got up to where the bolt moves (to strike the ball) it doesn't hit hard enough to move the ball anywhere, and then when I add more pressure through the lpr, the pressure just blows out of the bolt, as if it had a broken o-ring like before.
Please help, I currently just want to get this marker fixed, so I can sell it, and put some more money into my back-up which has become my main gun (an 2k Autococker pump). I can post pics/links to videos on YouTube if needed.
Thanks for your help, anything is help at this point,
Jared
** This was also posted on PBNation**
PostPosted: Wed Jun 06, 2012 2:17 am    Post subject: Re: Freestyle FS-7 Help
What oring did you replace? Here is a walk through on the HE bolt assembly:
www.icdproducts.com/pa...embly.html
You said it was the small oring? Was it the 007? It needs to be replaced with a polyurethane oring. The buna orings do not work well there.
Balance your regulators according to this:
www.icd-owners.com/htm...ic&t=16630
For good measure, you should clean your HPR and LPR.
PostPosted: Wed Jun 06, 2012 2:26 am    Post subject: Re: Freestyle FS-7 Help
If you need a good 007 oring(polyurethane) I have a few that I could send your way. that is usually the culprit.
Balance the regs per the link mal posted and double check the stickies in the freestyle section and see if you may have missed anything.
JBacon
PostPosted: Wed Jun 06, 2012 2:41 am    Post subject: Re: Freestyle FS-7 Help
I replaced the H-007 o-ring, and i got the o-rings from o-rings online on ebay. here is the link to the add, if that can help anything.
www.ebay.com/itm/India...2830wt_742
also, with my luck, i have misplaced the 3 complete rebuilds, and the one missing that 007 o-ring, so i cant try the other small o rings to see if that would help.
I was reading up on some other things, would it help to just set the settings on the board back to stock? the previous owner used it for tourneys, so the settings (dwell mainly) are much different from what the Manuel recommends.
PostPosted: Wed Jun 06, 2012 2:47 am    Post subject: Re: Freestyle FS-7 Help
Do you know what board is in it? Do you have a picture of it?
Those orings are all buna. You need a urethane one for the 007 on the bolt stem.
PostPosted: Wed Jun 06, 2012 2:53 am    Post subject: Re: Freestyle FS-7 Help
Yeah that kit only uses buna orings(black rubber) the stem needs to use poly only, they are much stronger. That kit is good for the rest if the marker but the stem needs to be more tear resistant.
As for the board settings if they are still the same a when you used it last then you should be ok. I would only mess with it when you get the leak figured out.
JBacon
the top of the modes paper states right away "The 2005 FS-7 features predator LTD Programming available through TAG Sports." I have been using these directions to change modes so i believe that the predator ltd is what i have. If you give me a few min i can take a picture for you, if it will help.
Thanks.
JBacon
PostPosted: Wed Jun 06, 2012 2:55 am    Post subject: Re: Freestyle FS-7 Help
Thank you peters, sorry i didn't acknowledge you. How much would you charge for a few of those o-rings? if it is aloud to be discussed on here (still new just glanced over the rules)
PostPosted: Wed Jun 06, 2012 2:57 am    Post subject: Re: Freestyle FS-7 Help
No charge, I have quite a few that I will probably never use. Pm me and I'll get them sent out.
JBacon
PostPosted: Wed Jun 06, 2012 2:22 pm    Post subject: Re: Freestyle FS-7 Help
So, will this o-ring fix the firing problem, aswell as the small leak? or will i just have to put it in, and go from there?
Page 1 of 4
new balance 1530 saldi online
puma italia scarpe
onitsuka tiger chaussures
Last post by Johnonsmith in ICD Mech Markers on Sep 17, 2020 at 08:19:53
Huh?
Last post by Un2XS in PRP General Forum on Sep 16, 2020 at 06:33:40
Line SI Promaster
Last post by Un2XS in ICD Mech Markers on Sep 16, 2020 at 05:53:58
Classic Fox Sold On MCB
Last post by Un2XS in ICD Mech Markers on Sep 16, 2020 at 05:30:01
Last post by Un2XS in PRP General Forum on Sep 16, 2020 at 05:10:57
2K20's demo allows you to build by taking control
Last post by Megaomgchen in PRP General Forum on Aug 17, 2020 at 06:50:58
Madden NFL 20 Highlights Sports Sims Betting Explosion
Last post by Megaomgchen in PRP General Forum on Aug 17, 2020 at 06:50:24
RS3 is nonetheless a good runescape game though
Last post by Megaomgchen in PRP General Forum on Aug 17, 2020 at 06:49:34
