Latest: Tjone
Overall: 7904
Members: 1
Visitors: 124
Total: 125
 Members:
01: Monke > Home
43: Your Account
46: Your Account
Forums › Marker Talk › Problem/Tech forum › Feedneck woes.
Feedneck woes.
PostPosted: Mon Dec 31, 2012 6:22 am    Post subject: Feedneck woes.
Remember this guy? Yes, this bonebrake freestyle.
I played at a field that I had not been to in a long time on Saturday. More dumpy than I remember, but that is not relevant. The icing on the cake of the day was that I noticed that the feedneck on this freestyle would not stay tight. I believe the threads in the body are stripping out.
What options do I have? I don't (won't) want to separate the matching feedneck from the body. It gets tight enough that I think I could use red loctite to hold it in permanently, but I am hesitant to do that. Blue loctite? I really want it fixed.
kwik
PostPosted: Mon Dec 31, 2012 12:29 pm    Post subject: Re: Feedneck woes.
yah I'd say try the blue first and see if it holds up(not sure how aggresive u play and how often you dive/slide)
Who knows, could be from when they did the anno or something abd the threads got weaker.
homerj
PostPosted: Mon Dec 31, 2012 2:33 pm    Post subject: Re: Feedneck woes.
Yeah, I've stripped the anno off an icd feedneck before that wouldn't even try to thread in afterwards. The new anno could've been slightly thinner. If you want it fixed permanently there's always jb weld. I've used it with good results.
PostPosted: Mon Dec 31, 2012 2:44 pm    Post subject: Re: Feedneck woes.
Try red if you're not ever going to change it. If that doesn't work you might be stuck using jb weld.
PostPosted: Mon Dec 31, 2012 3:45 pm    Post subject: Re: Feedneck woes.
It is original anodizing.
I don't plan on changing it. It is a clamping feedneck, so there really isn't a need to change it.
PostPosted: Mon Dec 31, 2012 3:51 pm    Post subject: Re: Feedneck woes.
blue or red. you know the difference.
PostPosted: Mon Dec 31, 2012 4:39 pm    Post subject: Re: Feedneck woes.
I'll take the red pill.
PostPosted: Mon Dec 31, 2012 6:38 pm    Post subject: Re: Feedneck woes.
Good choice. Follow that rabbit.
I've used a dab of red on all of my clamping necks. I figure until they come out with a hopper that DOESN'T fit those necks, there's no reason to be swapping them out. Red holds better than blue and can still be removed later if you need to.
BTW, I really need to read more novels by Joseph Hell.
PostPosted: Mon Dec 31, 2012 6:51 pm    Post subject: Re: Feedneck woes.
Hah.
Catch 22 was really Heller's only hit. I own a copy of closing time, but I read that Yossarian sells out in it. I don't like that idea, so I won't read it.
eviladam
PostPosted: Tue Jan 01, 2013 12:20 am    Post subject: Re: Feedneck woes.
Use red, first off you don't want it moving because the movement will only help with shearing it off. Second you only need to heat it with a torch to like 350* which will do ZERO damage to you anno if you needed to get it off later. There is also green which works well in threadless applications or if your actually missing threads or say a bearing! also removable with heat, I've used them all and they work great. And it takes no time at all to strip a body of orings and hit it with a torch.
Wtb Indian creek design solenoid 982030
Last post by Tjone in ICD Gear Forum on May 30, 2018 at 21:33:32
Last post by lasoyapro in Paintball talk on May 25, 2018 at 18:38:48
Last post by Walkertl in ICD Mech Markers on May 15, 2018 at 19:06:39
Last post by 63VDub in ICD Gear Forum on May 02, 2018 at 17:01:55
Last post by Tzarector in ICD Gear Forum on Mar 30, 2018 at 04:05:35
Last post by Un2XS in PRP General Forum on Mar 25, 2018 at 21:32:43
WTB: Promaster
Last post by ViperXT in ICD Gear Forum on Mar 23, 2018 at 16:16:25
