Latest: nsgm23ip
Overall: 7935
Visitors: 182
Total: 182
33: Your Account
80: Your Account
118: Home
123: Home
127: Home
130: Home
135: Your Account
154: Home
159: Home
166: Home
167: Photo Gallery
168: Home
173: Home
176: Photo Gallery
Forums › Buy/Sell/Trade › Non ICD Gear Forum › FEP quest project
FEP quest project
PostPosted: Mon Aug 19, 2013 10:56 pm    Post subject: FEP quest project
Well... I hate spool valve markers...
Got this thinking positively, selling it viewing it negatively...
Alright, purchased it and it did work fine, then an o ring went bad in the bolt, so I replaced them all, then it started leaking down the barrel, got that fixed, now its venting out the back of the frame.
That's about all I know. Could be simple, and probably will be since I'm inexperienced with spool valve markers.
Yes, Nobody, I can still fix a bushmaster!
Since I purchased it, I have:
Put on a dye 0-300 lpr reg,
Put on a empire reg,
Replaced bolt o rings and lubed up the bolt.
Price: $85.00 shipped, I'll throw in a barrel for another $15.00, or/and a cp on off Asa for $20.00.
Check my other thread for pictures.
I need to free up some cash, so offer less if you want. This is just what I feel is fair.
Forrestball
PostPosted: Tue Aug 20, 2013 8:22 pm    Post subject: Re: FEP quest project
I have found that on all the dye spoolies I've had that sometimes very slight input pressure increases can be the difference between shooting perfectly at 280 fps and over-pressureized.
View user's profile Yahoo Messenger
PostPosted: Tue Aug 20, 2013 9:11 pm    Post subject: Re: FEP quest project
^ Gatcha, I'll try to build up pressure as see what happens.
Edit: to little pressure and it leaks down barrel or around solenoid are, to much pressure and it leaks out of the back of the frame and body.
PostPosted: Tue Aug 20, 2013 10:13 pm    Post subject: Re: FEP quest project
see what the FEP people on PBN say, but i'm thinking that it could be a hose or something like that. i don't know since i never even held a Quest.
PostPosted: Tue Aug 20, 2013 10:33 pm    Post subject: Re: FEP quest project
They don't have internal hoses, I'll check there stuff out.
PostPosted: Thu Aug 22, 2013 12:44 pm    Post subject: Re: FEP quest project
Ok, fixed the leak out of the back of the body, had to re loctite the two screws in the back.
The solenoid needs new o rings on the spool, two are cracked and it was overlubed so it was sticking.
Forrestball
PostPosted: Thu Aug 22, 2013 11:41 pm    Post subject: Re: FEP quest project
It seems like a lot of the time what people call a blown noid is just one of those spool orings. There's gotta be a place to buy those orings. Imagine all the broken noids that could be fixed instead of replaced.
butternutvalley
PostPosted: Thu Aug 29, 2013 6:57 pm    Post subject: Re: FEP quest project
Tempting! Come with a on/off asa?
ICDO Feedback - www.icd-owners.com/htm...ic&t=14665
I do as I please as long as it's been approved by the wife........or she doesn't know about it yet
PostPosted: Thu Aug 29, 2013 7:01 pm    Post subject: Re: FEP quest project
^ just did a trade with homerj, I'll let you know what goes on though, he'll be taking a look at it, and I'll be taking a look at a marker for him.
butternutvalley
PostPosted: Thu Aug 29, 2013 7:07 pm    Post subject: Re: FEP quest project
okey dokey
nike air foamposite
Last post by Angftr12 in Calendar of Events on Mar 20, 2021 at 10:50:17
adidas superstar pas cher
Last post by Angftr12 in Off Topic on Mar 20, 2021 at 10:43:48
