Visitors: 79
Total: 79
02: Your Account
62: Home
64: Your Account
Forums › General › Paintball talk › my status
my status
PostPosted: Mon Nov 10, 2014 2:27 am    Post subject: my status
It pains me to post like this. I have let things go and not been more active on the boards. Real life and my own shame got in the way. So i have to face the hole i dug and the responsibility that i took on. I won't be taking on any new work till i finish what's on my plate now. I need to turn the outstanding work back into the outstanding work I've been onown for.
Outstanding orders:
Rcracerlol
LCheung
Blitz121
INpaintballer04
iBeast
I have replied to PMs, but if you didn't get one, then your order will be out on Wednesday. I am currently working midnights, so getting to the PO on Monday morning is tough, and there is no guarantee that i will be up before they close. As well as Veteran's day on Tuesday means the PO is closed.
As i said, i am trying to fix things that are wrong. Bare with me and i will finish my work.
PostPosted: Mon Nov 10, 2014 2:40 am    Post subject: Re: my status
Hope everything's ok Doug.
Thanks for the update. Hang in there!
blitz121
PostPosted: Tue Nov 11, 2014 3:12 pm    Post subject: Re: my status
Take your time bud, I just wanted to make sure all was well. If you need resources from me(if I have them) I would gladly help out.
New ICD Bought used needing help
iBEAST
PostPosted: Mon Nov 17, 2014 10:15 pm    Post subject: Re: my status
No worries friend.
I just didn't want you to forget about my request! Just let me know when I can PayPal you for the ram sleeve and barb!
Thanks again buddie!
PostPosted: Wed Dec 17, 2014 1:12 am    Post subject: Re: my status
Ok, anyone was on the list in the first post, should have gotten their packages by now. LCheung and Schoop, you 2 are the last ones. LCheung, you have a PM as well. I am too low on supplies to make anymore harnesses, and hopefully after the Jan 1, i will get in more supplies to continue this.
This does not mean that any of the hard parts, like the OEM parts or my own Nameless parts are out. Far from it. If you need triggers, bolts, screw kits, oring kits, etc and so forth.
LCheung
PostPosted: Sat Dec 20, 2014 8:21 pm    Post subject: Re: my status
Got all my trigger frames back from nobody. Frame mod looks great. Received one harness which also looks great, I wish the OEM harnesses were this nice. Bolt is on its way and two more harnesses on back order. Thanks for following through and thanks for explaining your situation. Soon as your rolling on harnesses again I should need a few more.
PostPosted: Sat Dec 20, 2014 11:33 pm    Post subject: Re: my status
I hope to have the supplies after the New Year. I need to check with my suppliers on the parts. So i will update when they come in.
LCheung, i am glad you like the harness & the frame mod. I do suggest applying blue loctite on the screws to prevent them vibrating out. I don't do it for people as some might like a little or a lot of bkue loctite on them. Plus, it guves you a chance to take the harness in and out of the frame. The best method is to stick a pin punch(it still serves a purpose) in the open side, and then screw in the screws. You will feel it push out. When the screw grabs the first screw, set the 2nd frame screw. Then tighten them down after both catch the microswitch. So much better than beating the pins out. These are guns, not Harleys. Lets put the hammers away.
