What we have here:
Gold b2k2
Bob Long board (no lcd)
MacDev RED valve
Sonic Trigger frame
BE wraparound 45 grips
vapor bolt
12" cp
CheckIT vert ASA
32* gauge
b2k3 stock reg
Chrome detent
drop forward with CP On/Off
Vaporized
~~Reworked Low Pressure Regulator
~~Match Port and Polished Exhaust Valve
~~Quick Disconnect between Battery Tray and solenoid for easy disassembly.
~~Trigger Job, including heavier trigger spring and ultralight microswitch.
~~New LED, High-Intensity Red
~~Polish ALL moving parts
~~Replace all stock screws with Stainless Steel set
" it doesnt have pds but i still found it impossible to chop with this.. using an Old pre-y board evo2. i was maxing out the gun (thanks to the triggerframe and vapor trigger job) yet it was not skipping shots, or dry firing and absolutely no chops... every shot was a good true paintball. this was even with old 32 degrees dimpled paint."- InfamousJIM
I have yet to chop with it also.
Has some nicks from normal play on the body and drop. Great gun.
give me your email if you would like some pics
I'm looking for $350 for this sick gun.
NO TRADES!
Thanks.
