Visitors: 45
Total: 45
12: Your Account
26: Groups
40: News
Forums › Marker Talk › Problem/Tech forum :: Archives › Reg stuck and new reg doesnt fit :: Archived
BKOBALLA
PostPosted: Tue Nov 04, 2003 10:50 am    Post subject: Reg stuck and new reg doesnt fit
first off....i think i got this reg on here at tight as it will go...just because it was leaking.....now i cant get it offf....
strap wrench= slips cuz its cheap
wrench= TOOK OFF THE BOTTOM...AHHH...i need the top part off
mouse pad underside= possiblility...maybe im just weak..
this this is on there tight...any other hints that you guys have like heating...good gripping objects....etc..
secondly...at one time i have the stock reg off and my palmers on....i took of the palmers to see if that was causing the leaking problem.(from above)....i then took the stock off and tried to get the palmers stab back on but it doesnt fit...WTF....WHY WONT MY REG SCREW INTO THE THREADS!!!!
inference one- palmers threads are screwed....dont look like it...and it goes back onto my spyder...so i think this is a negative
inference two- its ***...i dont have any other ideas....but its like tight and i have to force it on so i know there is a problem...maybe i messed the threads up oon the BKO VA....but then why does the stock one go on!
see what yall can think up....my first plan is to get the reg off and try the palmers again
-Geoff
--G SLiM--
abarnhar
PostPosted: Tue Nov 04, 2003 11:26 am    Post subject:
I have a bike intertube chopped up and in my tool kit. Whenever I need to get something tight on, I just grab and twist. I've found it to be a better grip than a mouse pad.
If it gets desperate, spray some liquid-wrench or WD40 around where the reg screws into the gun. Give it a couple of minutes to soak in, and hopefully that will aid in getting the threads moving.
On the topic of threads, I had a similar problem with my 'Fox. The first expansion chamber I ever put on it wouldn't screw in. It seemed that ICD's threader is off just a bit. I don't know if that's the deal with yours or not, but I hear your pain.
Can't think... n00bs will get me
NickCaporal
PostPosted: Wed Nov 05, 2003 4:32 am    Post subject:
ya, I used a bike tire intertube to take off my stock rise. I also used vice grip pliers.
RooR
BKOBALLA
PostPosted: Wed Nov 05, 2003 9:15 am    Post subject:
ill try the intertube thing....so i need to cut it so its just one layer...not both sides when laying flat....and...the one problem of it keeps slipping.....even with good rubber sticky things.. like the anno is too slick or my sweat gets it greasy.
PostPosted: Wed Nov 05, 2003 10:59 am    Post subject: Re: Reg stuck and new reg doesnt fit
if it was leaking why did you screw it on super tight? You should have tried changing o rings or something.
