Menu: |
Donations |
Donate and suport ICDO! |
Forums › Marker Talk › Problem/Tech forum :: Archives › Need help with ramping shootdown :: Archived |
Need help with ramping shootdown Have a problem with your marker? Ask here
View previous topic :: View next topic |
Author |
Message |
bushyman06 Amateur
Joined: May 28, 2005 Posts: 344 Location: seven-two-seven
Posted: Mon Aug 08, 2005 6:26 am Post subject: Need help with ramping shootdown |
Yesterday was my first time playing with my Sonic, on ramping. And I loved it. I don't think I could play again without ramping, its so nice.
Anyways, I noticed that when ramping, the balls had VERY inconsistant velocities. Like, every 9th, or whatever, shot, would kinda drop off, and the balls eventually would get back to full velocity. It was at the point when i was just messing around shooting, one ball actually kinda rolled out of the barrel.
any idea's? thanks.
(marker=sonic bushy, all the sonic goodies, 2k4 chaos, cp reg, kapp asa, cp on/off, P.E. tank)
Back to top |
Big_Mac Amateur
Joined: Sep 23, 2003 Posts: 486 Location: in a bunker in Iraq
Posted: Tue Aug 09, 2005 7:57 am Post subject: |
regs aren't keeping up with the rof. I suggest you clean and lube them both first and try again. It's also possible that the on/off center pin is actually obstructing the flow of air from the tank if you have it turned all the way in. Try turning it back out 1/2 turn and see if that doesn't help.
_________________ Stupidity Kills |
Back to top |
bushyman06 Amateur
Posted: Tue Aug 09, 2005 3:30 pm Post subject: |
ok, i took apart my LPR to lube it, and decided to clean my valve too. I then noticed that the silver piece that gets hit by the hammer was almost 100% unscrewed from the little brass piece with the red oring on it, so i tightened it, and lubed everything. hopefully that fixed it. ill also lube my CP just to make sure though. thanks.
Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
Photo Gallery Pics... |
Forums scroll Last posts |
Last 10 Forum Messages |
