New Today: 1
Visitors: 257
Total: 257
65: Your Account
114: Home
177: Photo Gallery
178: Home
181: Photo Gallery
182: Photo Gallery
187: Photo Gallery
195: Home
205: Photo Gallery
209: Photo Gallery
218: Photo Gallery
221: Photo Gallery
224: Photo Gallery
225: Photo Gallery
228: Photo Gallery
229: Home
231: Photo Gallery
234: Photo Gallery
256: Your Account
257: Forums
Forums › Marker Talk › Problem/Tech forum :: Archives › Need ya fellas' creative help (Chaos Chip) :: Archived
abarnhar
PostPosted: Sun Nov 09, 2003 10:35 am    Post subject: Need ya fellas' creative help (Chaos Chip)
Hey all,
I just got my protochaos chip in and it doesn't fit! The battery won't fit in the grip because the components on the chip go too far down, and the chip is too broad to fit in the tray. The only solution I have is to put the 9v in the tray (ahhh!).
Any suggestions?
Can't think... n00bs will get me
PostPosted: Sun Nov 09, 2003 11:11 am    Post subject:
Cut the useless piece of the board off and stick the board in the tray.
abarnhar
PostPosted: Sun Nov 09, 2003 11:20 am    Post subject:
The chip itself is physically too broad. The board would fit w/o the chip. Very Happy
NickCaporal
PostPosted: Sun Nov 09, 2003 11:37 am    Post subject:
a newbish/ghetto idea....... cut out rubber from each side of your grip panels, (maybee with a dremel or sumpthing) so the batterey will have more room, and cut in the other side so the board will have more room too.
RooR
abarnhar
PostPosted: Sun Nov 09, 2003 12:48 pm    Post subject:
Good suggestion, I looked into it, but I think to trim off enough to get the battery and the chip to fit would basically destroy the grips.
PostPosted: Sun Nov 09, 2003 12:59 pm    Post subject:
well i'm sure that you can find way to stick ur board in the tray. Maybe at an angle? Since there is a ton of room in the tray in the front of it maybe like angle the board?
abarnhar
PostPosted: Sun Nov 09, 2003 1:03 pm    Post subject:
Angle... Embarassed I'm a moron
(nobody sig that please)
PostPosted: Sun Nov 09, 2003 1:11 pm    Post subject:
Very Happy
abarnhar
PostPosted: Sun Nov 09, 2003 2:27 pm    Post subject:
Alright... angling the chip didn't work. So, I've decided to the leave the battery in the tray (it's only two extra screws). I think that once I have the time, I'm going to do the hopper power mod off of Tank's net. That way the gun will have juice and the battery will be at-hand. I'll probably also intellifeed it at the same time, so it's going to be a hell of a harness coming out of the BKO going to the hopper!
redmike
PostPosted: Fri Nov 14, 2003 3:59 pm    Post subject:
I had the same problem. What eventually worked was that I pushed the board up as far as it would go (only a few centimeters) and the battery finally fit with a little coaxing. Also, I got rid of the stock grip and put a pair of new Dye Grips on it. Everything fits fine except that the screw that holds the board in place won't go in (due to the screw holes not lining up. So my solution was to put a zip tie at the bottom of the grip to hold everything in place and so that there are not any gaps where paint can get in. Th sticky grip hold everything firmily in place due to them being one piece. Hope this helps. Very Happy
These are just some examples
