New Yesterday: 1
Visitors: 118
Total: 118
38: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › polishing ram :: Archived
polishing ram
jeb1
PostPosted: Fri Jul 15, 2005 4:50 pm    Post subject: polishing ram
hi i got a b2k4 and i wanted to polish the ram arm a bit i was wondering if you jsut use the highest # sand paper you can find to polish it or us brasso?
thank for the info
adammiddagh
PostPosted: Fri Jul 15, 2005 9:42 pm    Post subject:
If you use sandpaper, use extremely high grit. Like 1000+ grit.
I am not sure what brasso is, but if it is like mothers polishing
wading, it leaves a finish behind that may not work to well.
Personally, I recommend using scotch pad or steel wool. If
you use the steel wool, plan on disassembling the entire ram
and cleaning when done to make sure all of the steel wool
gets cleaned out of the ram.
Remember, the purpose of this mod is to make a super smooth
ram shaft, not to make it smaller.
PS
I believe there should be directions for several mods under "ICDU"
on the menu to the left of the page.
bushyman06
PostPosted: Sat Jul 16, 2005 5:52 am    Post subject:
i think brasso is steel wool?
robof9
PostPosted: Tue Aug 30, 2005 6:25 pm    Post subject:
brasso is used to clean brass, is liquid like a polish, not a pad or s/wool
robof9
PostPosted: Tue Aug 30, 2005 6:26 pm    Post subject:
can u use dremel with polishing pad on????
PostPosted: Wed Aug 31, 2005 12:59 pm    Post subject:
do not use brasso.
do use super fine steel wool or any wet sand paper that is marked for polishing metal, 1000+. I have used a dremel before but i find dremels are better for other applications. the easiest way ive found to do the shaft is to take it all apart. so that your left with just the shaft and attach it to a cordless drill so you can spin it. (DO NOT ATTACH IT TO THE SIDES WITH THE THREADS!!!!) turn on your drill and take your steel wool or sandpaper and go at it.. I used steel wool first for about 10min and then switched to the wet sand paper (keep dipping the wet sand paper into a cup of water, it works much better when wet) for another 10 or 15min. it now looks like a mirror Wink
jeb1
PostPosted: Thu Sep 01, 2005 8:58 pm    Post subject:
tolkas on the hammer jsut sitt there and jsut sand it for like ever witht eh steel wool? and another question on lightening your hammer i know you can use a grinder but how do you keep the sides balanced? i know a steel laith would work better but i dont have the means to get to one.
PostPosted: Fri Sep 02, 2005 1:08 pm    Post subject:
polishing the hammer isnt as important as the shaft. buy yeah steel wool and wet sandpaper will do it.
as for lightening the hammer ... i wouldnt do it if you only have one hammer.. buy an extra and experiment on that. or just have someone who has already done it to do it for you.
pump
I like bukkake!
I like bukkake!
PostPosted: Fri Sep 23, 2005 4:48 am    Post subject:
i have used only Flitx and no steel wool or sand paper
takes a while longer but hey still worked damn well for me
same idea put non threaded side into drill chuck
rag with polish, and uh uh uh hehehehehehe you get the idea
the ram housing you need to fit a plishing tip into the housing and use metal polish, pretty easy when you get the hang. just dont over do
autotriggers for sale
Shocktech B2Ks
NIB Warp Feeds FS
goleta_pbrob
PostPosted: Fri Sep 23, 2005 5:46 pm    Post subject:
ok you might think its stupid but i used my girlfreinds finger nail file. it is the really fine foamy type. it worked really good. then i just used a little bit of green scotch bright. its like silk now.
