Visitors: 75
Total: 75
75: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Little helpfull hints for your BKO. :: Archived
PostPosted: Tue Oct 07, 2003 8:29 am    Post subject:
Well for me i found out that the solinoid wasn't screwed tight enough to the ram and it caused a leak. Make sure its screwed in tight! If you hear a leak inside your gun check out the solinoid when you take it apart. It took me a while to figure it out but i'm damn glad i found it out!
Oh also when you get the gun out of the box make sure to tighten the ball bearing inside the bolt to a desired tightness where you can still get the pull pin out but it won't fall out if you hold the gun upside down. That happened to me and it took me on the field walking back to the staging area and it took me around 15 min to locate the friggin bolt and pin.
rick1000
PostPosted: Sun Oct 26, 2003 7:11 am    Post subject: bko helpful hints
This is a worthwhile thread, eveyone post here and it will be easier for new bko owners and not so new to set up there guns. The one good tip that I can think of that I got from this sight is the Hellbore mod. If you are having problems w/ double feeding, try to find a small diameter hose to fit snuggly w/out expanding your oring detent. These can be found at any hardware store. But be sure you don't increase the size of your oring with too big a piece of hose as this will lead to your bolt dragging against the oring and shooting it out. What this does is stiffen your detent to help prevent double feeding.
PostPosted: Tue Nov 04, 2003 9:52 pm    Post subject:
Once you get a chaos board word of advice:
SET IT UP!!
I played a whole day w a crap load of trigger bounce and i chopped like a mofo because i didnt set up my damn trigger frame. It really sucks.
Oh well i hope i dont chop next time but anyways the manual is in the manuals and files section of this site.
GOOD LUCK!
rick1000
PostPosted: Wed Nov 05, 2003 9:30 pm    Post subject:
What do you mean by setting the trigger frame up? Are you talking about the debounce and dwell? I am thinking of getting a chaos for my b2k3 and a vapor valve, is the chaos worth it because I have a Halo on my bushy and I can rip off some pretty impressive strings with the bounce I get in my trigger. Do you lose the speed when you install the chaos?
PostPosted: Wed Nov 05, 2003 9:38 pm    Post subject:
You gain massive amounts of speed w/ the chaos. Yea i mean the debounce and dewell and other stuff.
vincib
PostPosted: Sun Nov 23, 2003 7:38 am    Post subject: Dwell and timing?
I thought BKOs came from ICD preset and were not adjustable. If thats not so on the stock how are things adjusted?
Keo
PostPosted: Sun Nov 23, 2003 10:16 am    Post subject: Re: Dwell and timing?
do you mean the board? if so there not adjustable
PostPosted: Sun Nov 23, 2003 12:24 pm    Post subject:
SET IT UP!!
Wow my writing professor was right when he said american reading comprehension was going down the drain.
Big_Mac
PostPosted: Mon Dec 08, 2003 6:32 pm    Post subject: hints
if you're keeping the stock LPR you will have to keep it clean and lubed.
Stupidity Kills
Bko_monkey
PostPosted: Tue Dec 09, 2003 2:27 pm    Post subject:
yeah to stop double feeding cut a piece off the macroline and stick it in the o-ring detent. also keep the regs all lubed.
