Visitors: 95
Total: 95
28: Your Account
49: Home
50: Your Account
86: Home
89: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › my bko 04 help :: Archived
my bko 04 help
braha
PostPosted: Sun Dec 24, 2006 3:41 pm    Post subject: my bko 04 help
i have a bko 04 and it can not shoot stright at all i tryd diffrent barrles like frek kits and i want to know what els could i do to make my bko a good gun like what Upgrades or mods could i do to make it better
ryan braha
View user's profile Visit poster's website ICQ Number Yahoo Messenger
Cruel_Intentions
PostPosted: Sun Dec 24, 2006 3:44 pm    Post subject: Re: my bko 04 help
Are you shooting at a good FPS? Are you using quality paint? Does your barrel bore match up with your paint size? I've slipped on a log in a woodsball game and gotten sand in my barrel, chopped some paint and I couldent shoot straight after that untill I cleaned it out.
adriann222
PostPosted: Sun Dec 24, 2006 3:51 pm    Post subject: Re: my bko 04 help
Ok, well we need to obviously go back to some basics here so I'm gonna write this from the perspective that you are a 100% newb. Don't take this as an insult I just want you to have a thread that can help you figure out future issues.
Accuracy- This is effected by bore to barrel match, quality of the paint, and the FPS at which you shoot at. That means if you have crappy accuracy you need to:
1. try to match your paint to your barrel size
2. Get only good quality paint (no walmart crap)
3. Get your FPS at 250 to 285.
Gas Consumption- this is effected by the flow of the valve, blowback by the bolt, LPR pressure, and HPR pressure. If you are getting few shots per fill:
1. Reset your regs (I won't go into this but there is a stick in ICDU)
2. Check for excessive Blowback
3. switch out your valve for a high flow + light spring.
4. make sure your LPR is not fluctuating (may require replacing o-rings)
BPS- This is determined by the board you have, your loader, and your cycle speed. If you want to increase this then:
1. get a fast loader (halo, pulse, ect)
2. Get a new board
3. Polish and port your rams
Since you have a stock 04 BKO you have a good quality gun. I've heard you talk about getting PDS. If you get a good loader you really shouldn't need it. But outside of that look at my list and then determine what you want to change and then decide what you want to do.
Hope that helps.
MY FEEDBACK
zoidberg212 wrote:
braha
PostPosted: Sun Dec 24, 2006 5:38 pm    Post subject: Re: my bko 04 help
no i now what your talking about i have a frek kit and use the wright inserts and have tryd a helo b loader and im shooting at 290-295 feet per second and and i play in Tournaments and use higher grad paint so its none of throes so I now have done these things the only thing I haven’t done is check the blowback how do I do that so I guess I am newb
because I have no clue how to do that can you help me thanks
ryan braha
Cruel_Intentions
PostPosted: Sun Dec 24, 2006 5:44 pm    Post subject: Re: my bko 04 help
CHECK FOR BLOWBACK:
Take off your hopper, and put an index card or peice of constructon paper on top of the feedneck and fire. You could also put 2 or more balls in the feedneck and fire one shot, if the paintballs in the feedneck pop out, theres blowback.
adriann222
PostPosted: Sun Dec 24, 2006 6:11 pm    Post subject: Re: my bko 04 help
I would also tune down your FPS. Once I get over 285 I see a decrease in accuracy.
I don't know why this is I just do. I actually usually run at 260 cause that gives the best accuracy and it lets me drop shots pretty well behind bunkers.
MY FEEDBACK
braha
PostPosted: Sun Dec 24, 2006 8:02 pm    Post subject: Re: my bko 04 help
hay thanks for the help i try thes things after x-mass thanks
ryan braha
