Visitors: 37
Total: 37
01: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Freestyle won't fire, pressurize and leaks :: Archived
tippett
PostPosted: Wed Mar 14, 2007 12:12 am    Post subject: Freestyle won't fire, pressurize and leaks
I have a completly stock Gen 1 freestyle that will not hold pressure and when air is applied it leaks everything out the barrel. I have checked and relubed every oring and I am at a complete loss.
tdopb
PostPosted: Wed Mar 14, 2007 1:11 am    Post subject: Re: Freestyle won't fire, pressurize and leaks
check your regs
i kill people... lots of people.... and maybe eat them too
True paintballers love boobs. If you are a true paintballer put this in your sig.
tippett
PostPosted: Wed Mar 14, 2007 1:18 am    Post subject: Re: Freestyle won't fire, pressurize and leaks
I have i can't even get my gauge to read that it is holding any pressure as soon as i start to turn the hpr in it leaks.
PostPosted: Wed Mar 14, 2007 12:55 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
There are a few possibilities for that problem.
A good start would be to carefully disassemble and clean and lube up the LPR and HPR. Also, clean and lube the bolt assembly.
I'm not all that familiar with FSs but if the LPR is not putting out any pressure, I believe air will just leak out the bolt.
I'd suggest following the manual as far as setting up the HPR and LPR. It requires gradual adjustments.
I'd suggest starting with the HPR at zero pressure and the LPR adjusted so that it will output some pressure as soon as the HPR let's air through. As you gradually increase the HPR pressure, adjust the LPR pressure as well so that that bolt will cock back enough to clear the feedtube.
This should get you started.
Cheers
tippett
PostPosted: Wed Mar 14, 2007 5:12 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
Thanks Doc, I tried all that and still nothing. The problem I am experiencing is such that when I air the gun up it does not have hold any pressure and the air goes straight through the gun and out the barrel. I have tired airing it up with the LP all the way in all the way out in the middle nothing works. I have taken apart both the LPR and HPR regreased and put it all back together twice. I have also cleaned and lube the bolt and firing chamber but still nothing the air just runs right through the gun. This is quite frustrating.
Thanks again for any help.
Tippett
PostPosted: Wed Mar 14, 2007 8:46 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
Sounds almost like the LPR is either not getting any air or is not letting any air through to cock the bolt. Or, the Low pressure air passage from the LPR to the solenoid, to the bolt assembly, is blocked.
When you air up, will adjusting the LPR make any difference in what the bolt is doing? (ie. as the LPR pressure is adjusted up, the bolt should gradually get cocked back.
tippett
PostPosted: Wed Mar 14, 2007 11:15 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
I would say no however I took the back off again and pushed the bolt forward with the LPR all the way in and the hpr backed off competly I slowly start to add air and I could hear the soleniod clicking and pushing the air but the bolt remained forward and the gun did not recock, so I started to back off the LPR and the bolt let out a pop and air began to leak out fast again. However, when the bolt is back before appling I can't get any response other than air rushing out the barrel.
PostPosted: Wed Mar 14, 2007 11:52 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
You may already know this but the LPR actually is what cocks the bolt back. Instead of backing off the LPR in the above process, did you try increasing the LPR pressure? It sounds like as you "back off the LPR" and the bolt lets out a pop, the bolt is slamming forward and stays forward thus allowing the air to rush out as it's supposed to do.
If you max out the LPR and the bolt still isn't cocking back, then something is wrong with the LPR system.... could be the LPR or somewhere along the air passage.
tippett
PostPosted: Thu Mar 15, 2007 12:09 am    Post subject: Re: Freestyle won't fire, pressurize and leaks
I couldnt go any further in with the LPR that is why I backed out, also I have tried another stock reg (I have a gen 2 in pieces in my basement) and an STD LPR nothing with either of those LPRs connected. I was aware that the LPR cocks the bolt I still cant get the bolt to cock. IF at all possible could u help me narrow down the air pathways.
PostPosted: Thu Mar 15, 2007 4:48 pm    Post subject: Re: Freestyle won't fire, pressurize and leaks
Hmm.... Unfortunately, I'm not familiar with the exact air passages in the FS. I'm afraid this is as far as I can take it. You've done what I would've recommended already.... which is to swap out the LPR with something else as possibly, the LPR is faulty. I think you've proven that it's downstream from the LPR.
The only other thing that I can think of is to make sure none of the hoses are kinked.
Sorry. I don't know how else to help.
