Latest: bwh08
New Today: 1
Overall: 7916
Visitors: 241
Total: 241
07: ICDU
109: Home
131: Home
163: Photo Gallery
168: Photo Gallery
171: Home
173: Photo Gallery
178: Photo Gallery
182: Photo Gallery
195: Photo Gallery
198: Photo Gallery
203: Photo Gallery
223: Photo Gallery
228: Photo Gallery
231: Manuals & Files Downloads
236: Photo Gallery
237: Photo Gallery
241: Photo Gallery
Forums › Marker Talk › Problem/Tech forum :: Archives › lpr problem on my b2k4 :: Archived
psychomantis125
PostPosted: Thu Mar 15, 2007 5:13 pm    Post subject: lpr problem on my b2k4
hi, new here but ICd owner for over a year now, and i heard that the lpr sux on the b2k4 but the first time i used it it seemed fine so i didn't buy a new reg, but now i don't know whats wrong for some reason when i hook my air tank up it pressuirezes to 300 which is not bad, and i turn the Hpr untill i hear it bleed then turn it back about half a turn so ive done what most of you suggested but after a few shots the gague drops down to zero and i can't shoot any more..i get like 3 shots maxed, help anyone?
psychomantis125
PostPosted: Thu Mar 15, 2007 5:19 pm    Post subject: Re: lpr problem on my b2k4
+ i don't know if i might be out of air but i am not sure if thats the problem, this was happening b4 i ran low on air..any ides, i am going to get my tank filled today to see if that fixes it but if u have any suggestions they are apperciated
kruppy
PostPosted: Thu Mar 15, 2007 6:51 pm    Post subject: Re: lpr problem on my b2k4
I think you mixed up your HPR's and Lpr's on your first post.
The problem with the stock LPR is that it doesn't flow air quick enough to reach high rates of fire, which was one of the first things i noticed with my Bushmaster.
AS for your problem, i wouldn't blame this on a faulty LPR. Something is JUST not getting pressure, more then likely your noid because you said nothing about the HPR gauge reading zero. My bet would be that you have you LPR adjusted WAY to loo and pressure is getting past very slowly, therefor explaining your 3 shoots, as it takes that long to start shooting after you hook up your tank.. a low tank would also explain this so check that and make sure you screw it in all the way!
2k1 MacDev Sonic Autococker
- E-Bladed (undrilled)
- Shocktech Feedneck
- 15* Asa
psychomantis125
PostPosted: Thu Mar 15, 2007 9:37 pm    Post subject: Re: lpr problem on my b2k4
u said something about a hrp gauge? thers only one gauge on my gun? i dunno if thats the high or low one or anything but that one reads 300, then drops after 3 shots
ccmu
PostPosted: Thu Mar 15, 2007 9:51 pm    Post subject: Re: lpr problem on my b2k4
That's the HPR gauge. In order to try to rectify your problem:
1. Make sure your ASA is fully-engaging the pin valve on your tank. Some ASAs don't play nice with certain brands of tank regs.
2. Lube your HPR.
Ebay Feedback
psychomantis125
PostPosted: Thu Mar 15, 2007 10:27 pm    Post subject: Re: lpr problem on my b2k4
oh ok so its the hrp gauge..so to restate my problem, the hpr will read about 300 when i slip on my tank and then afte a few shots it will drop down to zero and not fire anymore..any ideas?
kruppy
PostPosted: Thu Mar 15, 2007 10:46 pm    Post subject: Re: lpr problem on my b2k4
try screwing your tank in further.. more then likely the problem.. happened to me the other day for the first time and i've been playing for 3 years with my tank... Definetly the culprit in your case..
- 15* Asa
psychomantis125
PostPosted: Fri Mar 16, 2007 12:03 am    Post subject: Re: lpr problem on my b2k4
ok,i'll try that tomarrow once i fill my tank and update you, thanks alot i hope thats the problem
psychomantis125
PostPosted: Sat Mar 17, 2007 1:37 am    Post subject: Re: lpr problem on my b2k4
Hello, an update if anyone is still wiling to help, ok so air tank full, tired setting my regs, the gauge reads 300, fire two shots and it goes to zero, only way to make it shot again is to unpressurize it and do it again, i am not sure if its like this for everyone, but my tank is very very hard to take off, and turning the knob for my uni mount is so hard to the point that i get blisters, is that normal? so im out of ideas and my hands hurt, thinking about buying a new cp reg and hope that fixes it?
kruppy
PostPosted: Sat Mar 17, 2007 2:17 am    Post subject: Re: lpr problem on my b2k4
If it was the reg it would recharge after SOME time..... I still think your problem is in your tank... do you have a different asa you could use? And yes i have a problem with my tank comeing out hard too.. i usually hold it bewteen my legs and twist the entire gun to get it off..
- 15* Asa
