Visitors: 302
Total: 302
38: Your Account
83: Home
91: Home
117: Home
123: Home
138: Home
142: Home
156: Photo Gallery
163: Photo Gallery
165: Photo Gallery
166: Photo Gallery
168: Photo Gallery
176: Photo Gallery
177: Photo Gallery
178: Photo Gallery
181: Photo Gallery
182: Photo Gallery
192: Home
195: Photo Gallery
196: Photo Gallery
199: Photo Gallery
203: Photo Gallery
206: Photo Gallery
209: Photo Gallery
210: Photo Gallery
211: Photo Gallery
213: Photo Gallery
215: Photo Gallery
216: Photo Gallery
217: Photo Gallery
218: Home
219: Photo Gallery
223: Photo Gallery
224: Photo Gallery
226: Photo Gallery
228: Your Account
234: Photo Gallery
235: Photo Gallery
237: Photo Gallery
238: Photo Gallery
240: Photo Gallery
241: Photo Gallery
243: Photo Gallery
245: Photo Gallery
247: Photo Gallery
250: Home
254: Photo Gallery
255: Photo Gallery
256: Your Account
257: Forums
258: Photo Gallery
261: Photo Gallery
262: Photo Gallery
263: Home
264: Photo Gallery
265: Forums
267: Forums
268: Photo Gallery
270: Photo Gallery
271: Photo Gallery
272: Photo Gallery
273: Photo Gallery
274: Forums
275: Photo Gallery
277: Forums
278: Photo Gallery
279: Home
280: Forums
281: Photo Gallery
283: Photo Gallery
285: Forums
286: Forums
287: Forums
288: Forums
289: Forums
290: Forums
291: Forums
292: Forums
293: Photo Gallery
294: Forums
295: Forums
296: Forums
297: Forums
298: Photo Gallery
299: Photo Gallery
300: Photo Gallery
301: Photo Gallery
302: Forums
Forums › Marker Talk › Problem/Tech forum :: Archives › Need better air efficiency :: Archived
immortal_clown
PostPosted: Mon Apr 02, 2007 8:41 pm    Post subject: Need better air efficiency
Ok well my gun has always been a gas hog and i can never get it to shoot very high unless i crank the poop out of the hpr and it starts making a weird noise and leaking aLOT out the gauge. I checked all the o-rings i can think of and have relubed the hpr , lpr and ram. Maybe there are some mods or somethign or any ideas what i could buy to get better air efficiency ...
PLEASE POST
kruppy
PostPosted: Mon Apr 02, 2007 8:53 pm    Post subject: Re: Need better air efficiency
IF this is a Bushmaster your talking about they are gas hogs! But you can get them to a responable spot fairly quickly.. when i had mine tuned right i was running a 130-140 psi HP... but my lp was at about 90 psi. I have since screw that up when my valve spring went bad.. but i'll get it back there eventually. Here's some helpful starter hints
1) VALVE!!!
2) If your gauge is leaking.. fix it.. some teflon tape woudl work wonders
3) lighten the valve spring..
2k1 MacDev Sonic Autococker
- E-Bladed (undrilled)
- Shocktech Feedneck
- 15* Asa
immortal_clown
PostPosted: Mon Apr 02, 2007 8:57 pm    Post subject: Re: Need better air efficiency
Yeah im shooting a vurtually stock b2k4 pds , but my guage only leaks when i turn the hpr rly high , so im assuming its bleeding out the excess air ? and what do i do w/ the valve :s ?
twinki
PostPosted: Mon Apr 02, 2007 9:10 pm    Post subject: Re: Need better air efficiency
get an aftermarket vavle silly. its much better. i might have one around if ya want pm me. stock valve is horrible
immortal_clown
PostPosted: Mon Apr 02, 2007 9:27 pm    Post subject: Re: Need better air efficiency
pmed
kruppy
PostPosted: Mon Apr 02, 2007 10:18 pm    Post subject: Re: Need better air efficiency
gauges shouldn't leak at all... gauges do not and should not bleed off any air.. the noid will however leak air if too much pressure is present! FIX IT
- 15* Asa
immortal_clown
PostPosted: Mon Apr 02, 2007 11:26 pm    Post subject: Re: Need better air efficiency
Really? because the guage on my hpr had a very tiny pin hole right in the very center which looks like it was obviously made when the guage was created. But the guage doesnt even work so im not sure why i still have it hehe. maybe ill just like super glue the hole or something rofl
kruppy
PostPosted: Tue Apr 03, 2007 9:24 am    Post subject: Re: Need better air efficiency
Mine as a hole 2.. but doesn't leak.. I don't beleive air even gets to that point of the gauge.. I believe gauges will work even without a cover on them.. That does allow moisture to escape!
- 15* Asa
immortal_clown
PostPosted: Tue Apr 03, 2007 10:16 am    Post subject: Re: Need better air efficiency
should i superglue the hole shut ?
twinki
PostPosted: Tue Apr 03, 2007 11:47 am    Post subject: Re: Need better air efficiency
no use teflon tape
