Latest: hongwei28
Visitors: 73
Total: 73
04: News
13: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › Freestyle probs, no velocity w/ reg balancing, FSDO :: Archived
mattftoo
PostPosted: Mon Dec 08, 2008 5:01 pm    Post subject: Freestyle probs, no velocity w/ reg balancing, FSDO
Balance the regs and tried from 200 to upper 300 psi on HPR. (not sure whether or not I have the HE bolt) Adusted LPR to pull back bolt, + 1/4 turn. No velocity, adjusting either one up or down has negative effect. FSDO between adjustments. I didn't try higher PSI until I had gone from 200 PSI to 300 in small increments first.
Stock regs, not alot of paint has been through this.
Do the 2 symptoms together suggest anything? Is there someone on the forum who works on markers reasonably?
Thanks.
PostPosted: Mon Dec 08, 2008 6:15 pm    Post subject: Re: Freestyle probs, no velocity w/ reg balancing, FSDO
try going up and down with your low pressure. The bolt only uses the LP to push it back, and the lp vents on the forward stroke. If it is too high, it can cause the bolt to "stick", and needs more high pressure to overcome. Too low, and the bolt does not completely return. Takes a little work to balance the regs for correct operation. Try thcgunsmoke for a vid on how to do it if you are unfamiliar.
Which FS do you have?
mattftoo
PostPosted: Mon Dec 08, 2008 10:23 pm    Post subject: Re: Freestyle probs, no velocity w/ reg balancing, FSDO
It's an 04 w/ an 05 body, if that makes any sense. When I got it, the milling was through the body. I returned it to ICD, and they didn't have any 04 bodies. They put an 05 on instead.
The low pressure adjustment is made after the high is set, as I understand it. If I get velocity, the bolt doesn't come back all the way. If I get the bolt back, no velocity.
www.seattleseahawksteamonline.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:30:45
www.oaklandraidersteamonline.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:25:49
www.lionscheapshop.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:21:15
www.tampabaybuccaneersteamonline.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:16:12
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:11:34
www.sanfrancisco49ersteamonline.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:07:38
www.coltscheapshop.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 03:03:34
www.greenbaypackersteamonline.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 02:59:31
www.authenticsdetroitlions.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 02:53:53
www.officialdevils.com
Last post by hongwei28 in Calendar of Events on Mar 25, 2019 at 02:47:43
