Visitors: 154
Total: 154
Forums › Marker Talk › Problem/Tech forum :: Archives › Problem :: Archived
Problem
pAiNtBaLlEr06
PostPosted: Tue Jan 06, 2004 5:34 pm    Post subject: Problem
I just got my b2k3 w/ pds today, but was used for 2-3 months. I air it up and I hear a leak in the solenoid, so I shoot a few times, and it stills leaks. I adjust the lpr the "cocker method". The PSI on the guage rises, up to about 300-400psi, solenoid still leaks. I'm thinking it's a lpr and hpr rebuilding/relubing time?
PostPosted: Tue Jan 06, 2004 6:30 pm    Post subject:
when you adjusted you reg "cocker style" did you adjust your hpr or lpr. the hissing is prly due to your lpr bieng to high not your hpr. the cocker style adjustment is meant for the lpr not the hpr. but if that doesnt work then yeah start by cleaning/lubing both regs.
pAiNtBaLlEr06
PostPosted: Tue Jan 06, 2004 7:28 pm    Post subject:
Yeah, I lowered the lpr so that it wouldn't cycle, and wouldn't fire, just click the solenoid, then turned it up, till it pulled the bolt back, then did another 1/2 turn, but still leaked. So, I'm thinking about getting the good old PMI Oil out and lubing everthing rubber on the hpr and lpr.
Keo
PostPosted: Tue Jan 06, 2004 7:34 pm    Post subject:
try lubing your noid gasket if not that clean the noid
pAiNtBaLlEr06
PostPosted: Tue Jan 06, 2004 7:35 pm    Post subject:
I'm not touching anything related to the solenoid until I've done everything else in order to fix it. If worst comes to worst, I'll call ICD, and maybe ship it to them to have them fix it.
Keo
PostPosted: Tue Jan 06, 2004 7:40 pm    Post subject:
if it's leaking from the noid, more than likely it's needs to be clean and lube
pAiNtBaLlEr06
PostPosted: Tue Jan 06, 2004 7:41 pm    Post subject:
OR the LPR/HPR isn't working correctly, giving too much pressure to the solenoid, making it bleed out the excess pressure. Usually, it's a problem with the regulators.
Keo
PostPosted: Tue Jan 06, 2004 8:16 pm    Post subject:
okay, then when you back the lpr out til it stop shooting, then turn it in til it fully cylce, your LPR should be more than 90 psi, and that would not cuase it to leak
Sangerpb
PostPosted: Tue Jan 06, 2004 8:44 pm    Post subject:
soak the noid gasket in white lithium or dow 33 or dow 55 over night and then re-install it, it worked for me.
rgarofalo
PostPosted: Tue Jan 06, 2004 8:47 pm    Post subject:
also check your o rings on your ram for tears that could cause the noid to bleed off
black to grey Freestyle
scepter kit
04 Glad
STD lpr
CF Grips
Gregs bolt mod
