Latest: kyagsn1u
Overall: 7937
Visitors: 190
Total: 190
20: Your Account
56: Surveys
123: Home
133: Home
151: Home
158: Home
176: Photo Gallery
190: Your Account
Forums › Marker Talk › Problem/Tech forum :: Archives › Just snapped the MI solonoid wire... on good friday... :: Archived
PostPosted: Mon Apr 04, 2011 5:33 pm    Post subject: Just snapped the MI solonoid wire... on good friday...
Just noticed this, the bolt sticks out farther than it should and blocks the ball from feeding, will this correct it self when aired up?
PostPosted: Mon Apr 04, 2011 6:22 pm    Post subject: Re: MI Bko bolt feeding problem.
Well the bolts on the ICD stuff are not adjustable so it should clear the breach. Remember, there is no air forcing the ram/bolt into the open position it is the ram spring. So no, airing up the gun will have no affect on the bolt's open position.
Check to make sure that the bolt pin is actually in the hammer slot and not infront of the hammer.
It is possible (not likely) that the hammer has come unscrewed from the ram shaft. Pretty easy to check this (just take the ram out of the gun).
Finally make sure someone didn't put in some piece of something under the ram cap to keep the bolt from going all the way back. Just remove the ram cap. I actually had to do just this, I installed a small piece of macro to make the bolt sit a bit farther forward as the eyes I milled in the breach were a tad low....but that is really a discussion for another time.
So, just try the above things and see what happens.
PostPosted: Mon Apr 04, 2011 6:29 pm    Post subject: Re: MI Bko bolt feeding problem.
when not aired up the bolt sits all the way open not blocking the breach, when you look down the feedneck the bolt should clear the breach, if not then your pin is probably not seating into the ram and is in front of it.
PostPosted: Tue Apr 05, 2011 12:01 am    Post subject: Re: MI Bko bolt feeding problem.
Fivestring, I think he's got the old square end ram, so he can't pull the cap. Check your pin placement and see if the hammer is unscrewed, as suggested.
PostPosted: Tue Apr 05, 2011 12:35 am    Post subject: Re: MI Bko bolt feeding problem.
screw is locked, pin is lined...
PostPosted: Tue Apr 05, 2011 1:05 am    Post subject: Re: MI Bko bolt feeding problem.
pics would help
PostPosted: Fri Apr 22, 2011 10:08 pm    Post subject: Re: Just snapped the MI solonoid wire... on good friday...
it works with electrical tape but it slides out...
PostPosted: Tue May 17, 2011 7:09 pm    Post subject: Re: Just snapped the MI solonoid wire... on good friday...
Uh, how long does the wire need to be striped for the solder to bond the two wires back together? i have 1/4 an inch both sides.
PostPosted: Tue May 17, 2011 7:24 pm    Post subject: Re: Just snapped the MI solonoid wire... on good friday...
It has to be 3/4 of the O.D of the wire to the 10th power, then subtract the total length of the wire. After you do that, take the I.D of the wire and multiply that by the bonding strength of the tin. Then you will have the length needed... comprende?
Asics novablast billigt online
Last post by kyagsn1u in Calendar of Events on May 08, 2021 at 01:07:24
Asics novablast donne rosa
Last post by kyagsn1u in Off Topic on May 08, 2021 at 01:02:03
Asics novablast hombre negras
Last post by kyagsn1u in Paintball talk on May 08, 2021 at 00:57:18
adidas continental mit
Last post by Mendyvlak in Calendar of Events on Apr 29, 2021 at 06:41:35
vans old skool online outlet
Last post by Mendyvlak in Calendar of Events on Apr 29, 2021 at 06:33:30
