Latest: sellcigarette
Overall: 7938
Visitors: 214
Total: 214
99: Home
127: Home
181: Photo Gallery
182: Photo Gallery
198: Photo Gallery
201: Photo Gallery
203: Your Account
204: Home
207: Photo Gallery
209: Home
213: Home
Forums › General › Paintball talk › Clamping Feedneck levers.....
kwik
PostPosted: Thu Dec 27, 2012 9:33 pm    Post subject: Clamping Feedneck levers.....
What is it that would make feedneck levers of one brand not fit on the ring of another. Like for CCM and AKA feednecks, if you wanted to add a lever you're pretty much SOL and CCM only made a limited run and they are gone as far as I know.
What I wanted to see is if anyone knew if it was the threading on the pin or the shape of the actual lever that makes say a dangerous power or Trinity lever not fit on an AKA ring?
I prefer to use levers than allen wrenches at the field and didnt know if I had any options with my existing CCM and AKA necks on my ICD markers.
PostPosted: Fri Dec 28, 2012 12:51 am    Post subject: Re: Clamping Feedneck levers.....
pretty sure ccm still has them but you need to email them about the levers
PostPosted: Fri Dec 28, 2012 2:43 am    Post subject: Re: Clamping Feedneck levers.....
the easiest thing to do is:
1) find an old stock feedneck(the high rise feednecks are the best).
2) wait for Empire to release the Sniper Clamping feedneck as a stand alone upgrade(talked to Simon about this and they will be released in 2013)or find a 05/06 Ego feedneck.
3) if there isn't a SP/Ion/ICD stub that comes with or available for it, take the feedneck, set it in the old feedneck and mark the feedneck.
4) get a cutting device and chop off the excess so that the Sniper feedneck will sit on the chopped off feedneck, so that there is enough material from the old feedneck to grip onto the chopped feedneck, but still low enough for the desired height you want the feedneck to sit.
5) get some sandpaper or a rat tail file and sand/file away the sharp edges.
6) thank Nobody for the great and easy installation tips while you use your lever feedneck.
PostPosted: Fri Dec 28, 2012 2:48 am    Post subject: Re: Clamping Feedneck levers.....
for those with ccm feeds, a redz clamping ring and lever fit them perfectly....thats what i got on my angel... its a ccm feed with redz lever and clamp ring....
kwik
PostPosted: Fri Dec 28, 2012 12:34 pm    Post subject: Re: Clamping Feedneck levers.....
thanks for all the good info guys.
I will look at the redz levers and see when next year empire comes out with theirs and go from there.
brock_averill
PostPosted: Sun Dec 30, 2012 2:17 pm    Post subject: Re: Clamping Feedneck levers.....
you can already buy the sniper feedneck at paintball gateway in the snipers parts section. I am not sure if nobody is saying that it will come with a threaded adapter in the future though.
04 AKA Immortal Viking
Empire Axe
PostPosted: Sun Dec 30, 2012 4:04 pm    Post subject: Re: Clamping Feedneck levers.....
i talked to Simon who designed the Sniper for Empire(and for that matter the mini, the axe, magna, events, E-flex, Trracer, parts of the Halo, etc)and he has said, that Empire will be selling a complete unit(cheaper than just getting the parts at gateway)with a threaded collar. even if there is no collar coming with it or no ICD threads, you can sacrifice a stock feedneck to give you the proper threads(so you don't need to guess and hope SP threads would work).
kwik
PostPosted: Sun Dec 30, 2012 11:00 pm    Post subject: Re: Clamping Feedneck levers.....
I originally asked because I saw the dangerous power levers were sold by themselves on some sites for 9 bux, shipping would probably have made it not worth it tho
PostPosted: Sun Dec 30, 2012 11:16 pm    Post subject: Re: Clamping Feedneck levers.....
well, if you can find a cheaper or more available clamper, go for it. i like the Empire/Sniper ones myself. but do show where these are located at. i will give an opinion on it Very Happy
brock_averill
PostPosted: Mon Dec 31, 2012 12:58 am    Post subject: Re: Clamping Feedneck levers.....
The dangerous powers ring/lever will NOT work on the AKA feedneck, I also assume it will not fit the CCM since that is smaller than the AKA ring.
Empire Axe
Wholesale Newport Cigarettes Online in concert
Last post by sellcigarette in Paintball talk on May 26, 2021 at 07:23:18
Newport Cigarettes Carton Cheap from the real item
Last post by sellcigarette in Paintball talk on May 26, 2021 at 07:22:39
Asics novablast billigt online
Last post by kyagsn1u in Calendar of Events on May 08, 2021 at 01:07:24
Asics novablast donne rosa
Last post by kyagsn1u in Off Topic on May 08, 2021 at 01:02:03
Asics novablast hombre negras
Last post by kyagsn1u in Paintball talk on May 08, 2021 at 00:57:18
adidas continental mit
Last post by Mendyvlak in Calendar of Events on Apr 29, 2021 at 06:41:35
vans old skool online outlet
Last post by Mendyvlak in Calendar of Events on Apr 29, 2021 at 06:33:30
