Latest: Agoston
New Today: 3
Overall: 7941
Visitors: 179
Total: 179
89: Home
94: Home
103: Home
106: Home
108: Home
118: Home
124: Home
126: Home
129: Home
138: Home
142: Home
143: Home
144: Home
147: Home
150: Home
164: Home
178: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › promaster eyes :: Archived
promaster eyes
PostPosted: Tue Jun 16, 2009 3:44 pm    Post subject: promaster eyes
Does anyone know the viewing angle or forward voltage of the stock PM eyes?
PostPosted: Tue Jun 16, 2009 4:07 pm    Post subject: Re: promaster eyes
Without knowing the brand and part number of the eyes it's hard to say with 100 percent certainty.
However, assumeing they are 3mm T-1 cased emitter/receivers....
*Forward voltage should be in the neighborhood of 1-1.6 or 7 volts at absoloute max 50mA current pulsed (20-30mA nominal continuous).
*Veiwing angle should be probably 25 degrees or less.
Hope this helps. What exactly are you trying to do?
PostPosted: Tue Jun 16, 2009 4:10 pm    Post subject: Re: promaster eyes
Just looking around the newark site. I have bought and used the ones listed on here, but I wanted to get what is right, not just what works.
PostPosted: Tue Jun 16, 2009 4:21 pm    Post subject: Re: promaster eyes
With out a Part number listing on a wiring diagram or something "official" from ICD, there's no way to know EXACTLY what brand/model they used. I know they used Fairchild Semiconductor brand 5mm eyes in those old setups. If you have working eyes then you can test the forward voltage you are getting and try to buy something equivelent, however that can be misleading since the max forward voltage might be 1.6v, you may only read at 1v. That doesn't mean as much as as the current not exceeding the secifications of the emitter.
PostPosted: Wed Jun 17, 2009 7:11 am    Post subject: Re: promaster eyes
Sadly, ICD only lists the specs for 12-pin wiring harnesses. I will email them and see if I can get some of the 22-pin specs.
PostPosted: Wed Jun 17, 2009 8:30 am    Post subject: Re: promaster eyes
According to the "official" ICD wiring diagram dated 4/02 in the gallery section here they used:
1N6264 5mm Fairchild IR emitter (metal can style) and
QSD723 5mm Fairchild Photo Detector/Transistor (black plastic case)
Since the date on the diagram is 2002, would that make it for a 22 pin or 12 pin board? I really don't think it matters, since functionaly they(the eyes) are the same. Do the promasters have 3 or 5mm eyes?
PostPosted: Wed Jun 17, 2009 12:28 pm    Post subject: Re: promaster eyes
3 mm eyes. Yea, i looked at he parts on the stock bushy harness on newark. Got the specs for that so I am assuming its in the same range.
PostPosted: Wed Jun 17, 2009 12:33 pm    Post subject: Re: promaster eyes
most likely
How can I quickly level up in WOW TBC Classic?
Last post by Agoston in ICDO's Next Top Builder on Jun 23, 2021 at 08:10:20
How to get dinosaur eggs in the Ark: Survival Evolved
Last post by Jonser in ICDO Fundraising / Merchandising on Jun 23, 2021 at 07:50:02
Pokemon Sword and Shield: How to get 6IV Shiny Ditto
Last post by Candy in Off Topic on Jun 23, 2021 at 07:03:08
Wholesale Newport Cigarettes Online in concert
Last post by sellcigarette in Paintball talk on May 26, 2021 at 07:23:18
Newport Cigarettes Carton Cheap from the real item
Last post by sellcigarette in Paintball talk on May 26, 2021 at 07:22:39
Asics novablast billigt online
Last post by kyagsn1u in Calendar of Events on May 08, 2021 at 01:07:24
Asics novablast donne rosa
Last post by kyagsn1u in Off Topic on May 08, 2021 at 01:02:03
Asics novablast hombre negras
Last post by kyagsn1u in Paintball talk on May 08, 2021 at 00:57:18
adidas continental mit
Last post by Mendyvlak in Calendar of Events on Apr 29, 2021 at 06:41:35
vans old skool online outlet
Last post by Mendyvlak in Calendar of Events on Apr 29, 2021 at 06:33:30
