Latest: Agoston
New Today: 3
Overall: 7941
Visitors: 378
Total: 378
61: Your Account
79: Your Account
110: Home
128: Home
132: Home
138: Home
150: Home
168: Photo Gallery
173: Photo Gallery
174: Photo Gallery
177: Photo Gallery
178: Photo Gallery
184: Photo Gallery
187: Home
191: Photo Gallery
192: Photo Gallery
194: Home
199: Photo Gallery
200: Home
205: Photo Gallery
207: Photo Gallery
208: Photo Gallery
210: Photo Gallery
213: Home
218: Photo Gallery
221: Photo Gallery
228: Photo Gallery
230: Photo Gallery
232: Photo Gallery
240: Photo Gallery
241: Photo Gallery
243: Home
244: Photo Gallery
245: Photo Gallery
248: Photo Gallery
249: Photo Gallery
257: Home
262: Forums
263: Photo Gallery
265: Forums
267: Forums
269: Photo Gallery
271: Forums
272: Forums
273: Forums
274: Home
275: Forums
277: Forums
279: Home
280: Forums
281: Photo Gallery
282: Photo Gallery
283: Forums
285: Photo Gallery
286: Forums
287: Forums
288: Forums
289: Forums
290: Forums
291: Photo Gallery
292: Photo Gallery
293: Forums
294: Forums
295: Photo Gallery
296: Forums
297: Forums
298: Photo Gallery
299: Forums
300: Forums
301: Forums
302: Forums
303: Home
304: Forums
305: Photo Gallery
306: Photo Gallery
307: Photo Gallery
308: Forums
309: Photo Gallery
310: Forums
311: Photo Gallery
312: Photo Gallery
313: Photo Gallery
314: Forums
315: Photo Gallery
316: Forums
317: Photo Gallery
318: Forums
319: Forums
320: Forums
321: Forums
322: Forums
323: Forums
324: Forums
325: Forums
326: Home
327: Forums
328: Forums
329: Forums
330: Forums
331: Forums
332: Forums
333: Photo Gallery
334: Forums
335: Photo Gallery
336: Photo Gallery
337: Forums
338: Photo Gallery
339: Forums
340: Forums
341: Photo Gallery
342: Home
343: Forums
344: Home
345: Forums
346: Forums
347: Forums
348: Forums
349: Forums
350: Photo Gallery
351: Forums
352: Forums
353: Photo Gallery
354: Photo Gallery
355: Forums
356: Forums
357: Forums
358: Photo Gallery
359: Photo Gallery
360: Forums
361: Forums
362: Forums
363: Forums
364: Forums
365: Photo Gallery
366: Photo Gallery
367: Forums
368: Photo Gallery
369: Photo Gallery
370: Forums
371: Forums
372: Photo Gallery
373: Forums
374: Forums
375: Forums
376: Forums
377: Home
378: Forums
Forums › Marker Talk › Problem/Tech forum :: Archives › I can't get this reg off. :: Archived
Koval15
PostPosted: Sat Feb 25, 2006 10:35 am    Post subject: I can't get this reg off.
Ok so i have a bko now and it has a sidewinder reg on it. Well im parting out the gun but the previous owner got the top of the reg really stuck in the asa. I have tried strap wrenches, strap wrenches with rubberbands on the reg, and hitting the asa with a hammer to lossen it and it still won't come off. What are your tricks to getting regs that are really stuck off?
PostPosted: Sat Feb 25, 2006 11:01 am    Post subject:
maybe try some heat..... might ruin the vert adapter, ive never had a reg i couldnt take of with 2 strap wrenches, just push each wrench off each other to get more power.... maybe try some PB blaster or liquid wrench ... these are just some ideas im throwin out
Koval15
PostPosted: Sat Feb 25, 2006 11:25 am    Post subject:
Tried heating it up still didnt work. Im thinking about just cutting the asa in half to get the reg out.
PostPosted: Sat Feb 25, 2006 11:43 am    Post subject:
be careful not to hit the threads on the reg if you do that.... how much did u heat it up? make that sucker red and and put some pressure on it with wrenches
Koval15
PostPosted: Sat Feb 25, 2006 11:49 am    Post subject:
I heated it up til i could hold it. I guess i should make it hotter?
B2K5_Mase
PostPosted: Sat Feb 25, 2006 11:51 am    Post subject:
Put it in a vice grio, heat it till its red, turn it out. If not, go buy some Aerokroil, which is better than liquid torch and pb blaster.
PostPosted: Sat Feb 25, 2006 1:24 pm    Post subject:
well if u can hold it with ur bare hand its not hot enough
are u worried about sratching any of it???
i would heat it up hot and try to put the vert adapter in vice grips or a vice then strap wrench the reg till it turns... ull probly mark up the asa a lot but at least ull get the reg out
Koval15
PostPosted: Sat Feb 25, 2006 1:39 pm    Post subject:
I dont care about the asa but i dont want the sidewinder scratched. I think the guy put gorilla glue, no joke, on the reg threads. I heated it up and now there is some glue coming out of some spots so i think its gorilla glue because it expands. i did heat it u before to where i needed to wear gloves to get it off but this time the thing started to smoke because of the glue. Im letting it cool down cause it seems like the glue was getting burned so that might loosen it a little.
OHS_Pyro89
PostPosted: Sat Feb 25, 2006 1:42 pm    Post subject:
Heres a little trick.
Take a 2x4, and take a drill bit a tiny bit smaller than the od of the reg. Then cut it in half through the hole.
Now, take the peices of wood, and put your reg in between it. Put them in a vice and crank down on it. This wont, or shouldnt, scratch the reg.
Since the asa is square, and not as important as the reg, take a Crecent wrench and twist counter clockwise.
If that doesnt work, get out the propane torch, and heat that sucker up for 10-15 seconds. Aluminum doesnt get red when its hot, it stays the same color. Plus, loctite will loosen up with some heat.
Then try again, that should work. Just be careful not to scratch the pretty regulator.
MMMMMMM Pickles.
PostPosted: Sat Feb 25, 2006 2:24 pm    Post subject:
if something in there is like melting it could maybe be the oring melting, but if its a liquid coming out maybe the kid used some expoxy, guriella glue i think would just burn when it gets hot, not return to liquid, since it hardens as a foam, try what OHS said with the 2x4, if that doesnt work, just keep the heat on it and then get the wrench on and try to take it of while it is hot!, dont let it cool back down
How can I quickly level up in WOW TBC Classic?
Last post by Agoston in ICDO's Next Top Builder on Jun 23, 2021 at 08:10:20
How to get dinosaur eggs in the Ark: Survival Evolved
Last post by Jonser in ICDO Fundraising / Merchandising on Jun 23, 2021 at 07:50:02
Pokemon Sword and Shield: How to get 6IV Shiny Ditto
Last post by Candy in Off Topic on Jun 23, 2021 at 07:03:08
Wholesale Newport Cigarettes Online in concert
Last post by sellcigarette in Paintball talk on May 26, 2021 at 07:23:18
Newport Cigarettes Carton Cheap from the real item
Last post by sellcigarette in Paintball talk on May 26, 2021 at 07:22:39
Asics novablast billigt online
Last post by kyagsn1u in Calendar of Events on May 08, 2021 at 01:07:24
Asics novablast donne rosa
Last post by kyagsn1u in Off Topic on May 08, 2021 at 01:02:03
Asics novablast hombre negras
Last post by kyagsn1u in Paintball talk on May 08, 2021 at 00:57:18
adidas continental mit
Last post by Mendyvlak in Calendar of Events on Apr 29, 2021 at 06:41:35
vans old skool online outlet
Last post by Mendyvlak in Calendar of Events on Apr 29, 2021 at 06:33:30
