Latest: kyagsn1u
Overall: 7937
Visitors: 239
Total: 239
26: Home
78: Home
83: Home
86: Home
98: Home
104: Home
111: Home
116: Your Account
130: Home
145: Home
149: Home
156: Home
157: Home
160: Home
163: Home
164: Surveys
167: Photo Gallery
168: Photo Gallery
174: Photo Gallery
181: Home
190: Photo Gallery
192: Photo Gallery
194: Home
195: Photo Gallery
197: Photo Gallery
206: Photo Gallery
208: Photo Gallery
212: Your Account
218: Photo Gallery
221: Home
226: Home
232: Photo Gallery
237: Home
238: Home
Forums › Marker Talk › Problem/Tech forum :: Archives › Installing Vapor Valve :: Archived
IOwnATippmann
PostPosted: Thu Jun 10, 2004 6:31 pm    Post subject: Installing Vapor Valve
How would one take out the stock valve and replace it with the vapor valve? Thanks a load.
RaGeN_aZn
PostPosted: Thu Jun 10, 2004 6:37 pm    Post subject:
u need to take out the asa, LPR, and the ram...then take off ur tray and unscrew the valve retaining screw. then take something long and skinny like a pencil or a chopstick and push the valve out torwards the LPR hole. then lube up the vapor valve o-ring and install it...remember, the lil tiny hole goes in the gun first.
PBN feedback> www.pbnation.com/showt...287002#pos
RaGeN_aZn
PostPosted: Thu Jun 10, 2004 6:41 pm    Post subject:
o yea, and then re-installs everything back on Razz
IOwnATippmann
PostPosted: Fri Jun 11, 2004 12:47 pm    Post subject:
Ive never taken off the asa before, how do I do that?
Harbinger
PostPosted: Fri Jun 11, 2004 1:37 pm    Post subject:
remove the hpr, and then use the proper allen key to remove the asa
View user's profile Visit poster's website ICQ Number MSN Messenger
IOwnATippmann
PostPosted: Fri Jun 11, 2004 6:07 pm    Post subject:
What would be the better to lube the valve? Lithium grease or silicon spray?
RaGeN_aZn
PostPosted: Fri Jun 11, 2004 7:56 pm    Post subject:
lithuim grease...
Leterrip
PostPosted: Fri Jun 11, 2004 8:46 pm    Post subject:
be careful when you screw the set screw back in to hold the valve in place....there should be NO PRESSURE on the valve from the set screw. if you screw the thing in too tight the valve will LEAK!! just screw it in until it merely touches the valve and that should hold it. just put some locktite or teflon tape around the set screw first to hold it in place since it's "floating there".
bushy86
PostPosted: Sun Jun 13, 2004 9:51 am    Post subject:
make sure u put things back properly, loctite the the valve screw lightly
RaGeN_aZn
PostPosted: Sun Jun 13, 2004 10:20 am    Post subject:
no need for loctite
Asics novablast billigt online
Last post by kyagsn1u in Calendar of Events on May 08, 2021 at 01:07:24
Asics novablast donne rosa
Last post by kyagsn1u in Off Topic on May 08, 2021 at 01:02:03
Asics novablast hombre negras
Last post by kyagsn1u in Paintball talk on May 08, 2021 at 00:57:18
adidas continental mit
Last post by Mendyvlak in Calendar of Events on Apr 29, 2021 at 06:41:35
vans old skool online outlet
Last post by Mendyvlak in Calendar of Events on Apr 29, 2021 at 06:33:30
